Password Protect VIs using VI server
No I've never done it but you should be able to iterate through your VIs using the LockState.Set Invoke Node. There is also a setting for applying a password to source in Source Distribution build spec.
Okay just created and example which will set a password on all VIs in a directory recursively - BE CAREFUL what you point it at :)
Batch Password Example.vi
Edited by Dan DeFriese
AHH VI.lib just got password protected!!!!
:D
Just out of curiousity... What's the use case for applying password protection on the VIs? I've never really thought about this before.
~Dan
:D
~Dan
To hide embarrassing spaghetti code :)
:D
~Dan
Or to prevent accidental changes to VIs in the vi.lib.  Of course changing the file to be read-only maybe an easier alternative for this.
... changing the file to be read-only maybe an easier alternative for this...
If you have the "treat read-only VIs as locked". Otherwise, dirty dots can happen.
Distributing code that is "locked - no password" works no matter what LV settings someone else has.
So if the file is read-only it can still be edited, (so a dirty dot) but you can't save it so any changes will not be kept, which in my mind is the real reason to set the file to read only.  Sure I could edit a VI that is read-only, keep it in memory and then the changes will be implemented, but as soon as I close LabVIEW (and changes are discarded) the VI will revert back to the original file.
