John Lokanis Posted July 25, 2013 Report Posted July 25, 2013 This is driving me nuts! I have a VI with a MCLB display. When I open this VI, I select a particular row (for example, row 3) and set the key focus to the MCLB control so the user can use the arrow keys to navigate without first clicking on the control. This works fine the first time I open the VI in my application. If the user presses the down arrow, the selection moves to row 4 as expected. If the user navigates to a different row (for example, row 8) and then in the main program takes an action that causes my MCLB VI to be activated again (this time selecting row 5), I bring the MCLB VI to the front most and again set the key focus to the MCLB control. Row 5 is highlighted as expected. But if the user presses the down arrow again, the selection changes to row 9, not 6 as would be expected. Even though the control value is set to row 5 and row 5 is highlighted, somehow the control remembers that the last row navigated to manually was row 8 and it thinks it is still on row 8! I have tried setting the active cell to the selected row to see if that fixes it but with no luck. I have also tried changing the order of when I set the MCLB value and the key focus but that seems to have no effect. Even if I close the VI containing the MCLB and then reopen it, it still remembers the row navigated to and not the newly set one. The thing that is bugging me even more is I vaguely remember having this problem years ago and solving it (I think) but I cannot remember how. Has anyone solved this or have any ideas? thanks for any thought or comments you can offer. -John Quote
Darin Posted July 25, 2013 Report Posted July 25, 2013 This is an oldie-but-goodie bug: http://forums.ni.com/t5/LabVIEW/Multicolumn-Listbox-Keyboard-Navigation-Bug/m-p/1286778/highlight/true#M533821 Similar behavior for the normal listbox as well. I have "solved" it by taking full control of the keyboard navigation using events. And yes it is a pain. Quote
John Lokanis Posted July 25, 2013 Author Report Posted July 25, 2013 Yup. Just dug up the code (had to go back to something I wrote in 2004 to find it) and I had ended up solving it the same way. That is one old bug. I wonder if it will ever get fixed... Quote
Darin Posted July 25, 2013 Report Posted July 25, 2013 I am sure they have top men working on it now. Quote
Popular Post Darren Posted July 25, 2013 Popular Post Report Posted July 25, 2013 There are some private properties you can use in LabVIEW 2012 SP1 and later that allow you to set the focus row of a Listbox or Multicolumn Listbox programmatically. Whenever you programmatically change the value, if you also programmatically change the focus row, it should behave in the manner you're looking for. I had heard the behavior was fixed natively to the controls in LabVIEW 2013, but it appears to still be an issue that we have to workaround programmatically. This VI (saved in LabVIEW 2012) contains the private properties you would need. Again, these properties were added in 2012 SP1, so they're not available in an earlier version. Oh, and it was a top woman, not a top man, who added these private properties for us. Focus Row Properties.vi 5 Quote
mje Posted July 25, 2013 Report Posted July 25, 2013 There are some private properties you can use in LabVIEW 2012 SP1 and later that allow you to set the focus row of a Listbox or Multicolumn Listbox programmatically. Whenever you programmatically change the value, if you also programmatically change the focus row, it should behave in the manner you're looking for. I had heard the behavior was fixed natively to the controls in LabVIEW 2013, but it appears to still be an issue that we have to workaround programmatically. This VI (saved in LabVIEW 2012) contains the private properties you would need. Again, these properties were added in 2012 SP1, so they're not available in an earlier version. Oh, and it was a top woman, not a top man, who added these private properties for us. Focus Row Properties.vi This behavior has irked me for some time. I also observe it in the Tree controls, do they have a similar private property? Quote
Popular Post Darren Posted July 25, 2013 Popular Post Report Posted July 25, 2013 This behavior has irked me for some time. I also observe it in the Tree controls, do they have a similar private property? I didn't think they did, but I was pleasantly surprised when I looked this morning. Here is the same property for the Tree (saved in 2012), also only available in 2012 SP1 and later. tree_FocusItem.vi Edit: Turns out the "Focus Item" property of the TreeControl class is only available in LabVIEW 2013 and later. My previous statement that it was available in 2012 SP1 is incorrect. 3 Quote
mje Posted July 25, 2013 Report Posted July 25, 2013 Darren, thank you. I haven't tested it yet, but you likely just fixed the longest outstanding defect on one of our products. Like button x Inf. 1 Quote
John Lokanis Posted July 25, 2013 Author Report Posted July 25, 2013 Thanks! This definitely fixed my problem. Please let me know who to buy a for at NI Week. One note: If you try to write -1 to the Focus Row, you get an error. Writing -1 to the value deselects all rows so sometimes I use this to purposely not have a row highlighted. I had to add some code to detect this and not set the Focus Row property in those cases. Nice to see this will be in 2013. Are you saying that this will be publicly available or that the focus row will automatically be set to the value? While we are on the subject of fixing the MCLB, here is something I would like to see: Set the number of visible columns and the minimum width of each column. When scaling the control within a pane, widen or shrink the columns so the requested number of visible columns is maintained. Allow us to set the control to auto scale all columns or a specific subset (so some columns maintain their width while other scale). I can do all this in code, but there is so much lag in handling the re-size events that it inevitably is visible to the user as the columns adjust. This gets especially problematic when there are multiple MCLBs in multiple panes on a panel. Oh, and do the same for Trees as well! thanks again for the help! -John Quote
Darren Posted July 25, 2013 Report Posted July 25, 2013 Nice to see this will be in 2013. Are you saying that this will be publicly available or that the focus row will automatically be set to the value? From what I could tell, we were *supposed* to see the focus row be correctly set while editing in 2013, but from my preliminary tests, it appears to still be a problem in 2013, and will thus still require the programmatic workaround. Quote
John Lokanis Posted July 25, 2013 Author Report Posted July 25, 2013 From what I could tell, we were *supposed* to see the focus row be correctly set while editing in 2013, but from my preliminary tests, it appears to still be a problem in 2013, and will thus still require the programmatic workaround. I'm ok with that but will the Focus Row property be public? Quote
Darren Posted July 25, 2013 Report Posted July 25, 2013 I'm ok with that but will the Focus Row property be public? The FocusRow and FocusItem properties are still private in LabVIEW 2013. I will add them to our internal list of properties to consider moving to public/scripting in LabVIEW 2014. Quote
GregSands Posted July 25, 2013 Report Posted July 25, 2013 I didn't think they did, but I was pleasantly surprised when I looked this morning. Here is the same property for the Tree (saved in 2012), also only available in 2012 SP1 and later. tree_FocusItem.vi Tree:FocusItem doesn't seem to work for me in 2012 SP1 (12.0.1f3) - I get an Invalid Property error: The property is not valid for this class. Listbox appears fine. Quote
Darren Posted July 25, 2013 Report Posted July 25, 2013 Tree:FocusItem doesn't seem to work for me in 2012 SP1 (12.0.1f3) - I get an Invalid Property error: The property is not valid for this class. Argh, you're right. When I checked this morning I was awash in several open LabVIEWs and checked the wrong one. The "Focus Item" property of the TreeControl class is only available in LabVIEW 2013 and later. I have updated my post above to reflect this. Sorry about that. Quote
Darin Posted July 25, 2013 Report Posted July 25, 2013 This is driving my nuts! Certainly only top men have this problem. Top. Men. (Those who do not get the original reference should at least get the Family Guy homage) Quote
John Lokanis Posted July 25, 2013 Author Report Posted July 25, 2013 Certainly only top men have this problem. Top. Men. (Those who do not get the original reference should at least get the Family Guy homage) Good catch. Never type while mad. I should have done a better job proofreading.. (we really need a :facepalm: emoticon on LAVA) Quote
John Lokanis Posted September 12, 2013 Author Report Posted September 12, 2013 This just saved me again with a single column listbox. Thanks again Darren! (Please lobby to make this public in the next version of LV) Quote
Darren Posted September 12, 2013 Report Posted September 12, 2013 (Please lobby to make this public in the next version of LV) I have added a link to this post to the CAR, and indicated that we should prioritize this over some of the other CARs I've filed about moving private stuff to public/scripting. 1 Quote
John Lokanis Posted August 25, 2014 Author Report Posted August 25, 2014 Looks like this is still private in LV2014. Quote
Darren Posted August 26, 2014 Report Posted August 26, 2014 Looks like this is still private in LV2014. I did what I could to lobby for these properties to become public, but they were not prioritized highly enough to make it into LabVIEW 2014. Quote
John Lokanis Posted August 26, 2014 Author Report Posted August 26, 2014 thanks for trying. I will just keep advertising this thread to those who find this bug. Quote
Mads Posted August 26, 2014 Report Posted August 26, 2014 This is an oldie-but-goodie bug: http://forums.ni.com/t5/LabVIEW/Multicolumn-Listbox-Keyboard-Navigation-Bug/m-p/1286778/highlight/true#M533821 Similar behavior for the normal listbox as well. I have "solved" it by taking full control of the keyboard navigation using events. And yes it is a pain. The first report of it was actually 1 year earlier - back in 2009... I do not see why we should need to set a Focus property to get this right...So instead of fighting to get that property made public (not that that's not nice as well), I would prefer it if no such property setting was needed (if that is made available it could instead be used to override what is then the default behaviour - in the rarer event that you would not want to focus on the current value). Quote
