How to display this in UML
I am doing design and want to show the following in a UML diagram:
Method is "GenerateNextX" and it returns class "X." X won't be held in private data, just stuck in a queue to go elsewhere, where it will be immediately consumed. There really is no single object that is holding onto this  "X" object. So, where in my UML do I define the "X" class? It seems aggregation and composition don't really fit, so I can't stick it on an existing diagram, as it relates to another class. But, I do want to define the class somewhere.
So the Method "GenerateNextX" belongs a class e.g. "Creator" class is that what you mean?
If so the Creator class has a normal Association dependency to the Class "X"
This is what Symbio's UML Modeller would show about that design.
(select an assoication and press Shift to open the Context Help)
Cheers,
Mike
