urgently requires help for a labview code
I need a help.. i want a labview code or model for the following "to plot an histogram using a random number generator.. the plot must be like a bell shaped curve( gaussian curve) .. pl help me out..
Regards
Clarke
Edited by james_clarke
I want the histogram plot to be in the form of the bell shaped curve..tried many things.. but the plot isnt similar.. need ur help
Yes. See the "Noise Statistics.vi" or "Probability Density Function Estimation.vi" in the LabVIEW example Finder.
Look in the Signal Processing->Signal Generation palette.  There is a Gaussian White Noise.vi in there that will give you noise with a bell curve distribution.
Now go to the Mathematics->Probability & Statistics palette.  There is a Histogram.vi in there that can create your distribution.  Make a graph from the output and you are done.
