prabhakaran Posted July 15, 2014 Report Posted July 15, 2014 Hi all, I am writing an avi file composed of u8 grayscale images using IMAQ AVI2 write frame function. But when I am reading the file image type with IMAQ AVI2 Get info the image type is shown as u32-RGB . I searched through net but I couldn't find a solution. Could I get help on the knowledge why it does so? Vision Version:13.0.0 Codecs Tried: Cinepak Codec by Radius,FF Video Codec 1 (FFV1) (NI Vision),Motion JPEG (NI Vision),Y800 Uncompressed Grey Scale (NI Vision),YUV 4:2:0 Planar (NI Vision). Thanks in advance, Prabhakaran Quote
hooovahh Posted July 15, 2014 Report Posted July 15, 2014 Post an example of your code so others can see what you mean. I don't have IMAQ so I won't be able to try it myself. Also if this is a real bug you will want to notify NI too. Quote
prabhakaran Posted July 17, 2014 Author Report Posted July 17, 2014 Hi hooovah, Thanks for reply in a short duration.Below is the example code I am using. AVI write read.vi Quote
prabhakaran Posted July 17, 2014 Author Report Posted July 17, 2014 Hi, It seems that the problem occurs in reading the avi file using avi2 open file . Because the IMAQ AVI2 Get Info provides output of U8 if used with the write session and U32 with read session. Is this a bug or are there any means to avoid this? AVI write read.vi Quote
Rolf Kalbermatter Posted July 18, 2014 Report Posted July 18, 2014 Hi, It seems that the problem occurs in reading the avi file using avi2 open file . Because the IMAQ AVI2 Get Info provides output of U8 if used with the write session and U32 with read session. Is this a bug or are there any means to avoid this? AVI is really only a container format and mostly meant by Microsoft to be used for real world video. What format the data is actually written in depends highly on the available codecs on your machine. Most likely it won't support U8 and/or greyscale without installing a very specific codec that supports such a format. And if you created such a formatted AVI you won't be able to replay it on machines that have not the same codec installed. The Windows AVI interface correctly changes the format to an available codec format that, at what it believes at its own discretion is the closest match to the incoming format. If you check the format of the resulting AVI file with some AVI file format checker you will see that it is already RGB when written on disc and the reading will simply read in what is on disc and has no way to magically know that it should convert it back to U8 greyscale. Quote
prabhakaran Posted July 19, 2014 Author Report Posted July 19, 2014 AVI is really only a container format and mostly meant by Microsoft to be used for real world video. What format the data is actually written in depends highly on the available codecs on your machine. Most likely it won't support U8 and/or greyscale without installing a very specific codec that supports such a format. And if you created such a formatted AVI you won't be able to replay it on machines that have not the same codec installed. The Windows AVI interface correctly changes the format to an available codec format that, at what it believes at its own discretion is the closest match to the incoming format. If you check the format of the resulting AVI file with some AVI file format checker you will see that it is already RGB when written on disc and the reading will simply read in what is on disc and has no way to magically know that it should convert it back to U8 greyscale. Hi Rolf, Thanks for your reply. But I have tried "Y800 Uncompressed Grey Scale (NI Vision)" codec. This codec comes along with NI Vision installer. From the name of the codec, looks like it supports grey scale images to be written. Earlier, we were able to write and read grey scale images using AVI1 vis and we don't have to specify codec in the AVI1 vis. Thanks, Prabhakaran. Quote
