Installation options dialog
Hi, folks.  Do you know - is there a way using the Labview project installer building tool to give the user an installation options dialog right after he double-clicks setup.exe?  The dialog would ask which kind of test station he wants to install, and then I need to install a different set of supporting files depending on his choice, along with the one EXE file.  It would be nice if I could name the shortcuts differently, too, depending on his choice.
Or maybe there's a better solution?
Thanks very much.   -Joe
Yup.  The NI installer is kinda limited.  So I usually wrap the NI install, into an Inno Setup installer for when I need more cusomization.  This can do things like have Full, or Custom installs, and of course installation location control.  I usually use ISTool to make, making one of these easier.
  • Like 2
