table+array
Right-click the Table Indicator and 'Create Constant'.  What you will notice is that the data type of the Table is a 2-D array of strings and you are creating a 1-D array.  Add one more build array and it will work (right-click the broken wire and it will even give you the option to insert Build Array).  Transpose the array as desired.
Edited by Darin
A table has rows and columns, you are only providing one dimension.  As suggested insert another build array between the one you have, and table indicator.
