Launch LabVIEW Editor - Quick Drop shortcut
I haven't found any way to launch IE from keybord and I decided to make my QD shortcut to do this.  I've used LabVIEW Icon API and build simple code as shown on snippet. Everything work fine when I want to change Icon of a VI holding the code, (ie. replace "QD Launch VI Ref" with reference to the VI) but the situation is different when I am using it as a QD shortcut.  I have to wait about 5-10 sec once Icon Editor is launched.  It's far to long.
Does anybody can tell me how I can do this process faster or give me another way I can run IE using keyboard?
Find the IE shortcut in the start menu. Right click on it and select properties. There is a field for you to define a shortcut key which is currently set to None..
Have you tried the Icon Editor that comes with GDS?
This VI gets loaded with LabVIEW and will open instantly.
(Tools->GOOP->Create VI Icon…)
If you have installed NI's GDS (http://sine.ni.com/nips/cds/view/p/lang/en/nid/209038)
You can find the IconEditor VI here:
LabVIEW 2013\resource\Framework\Providers\Symbio_GDS\EndevoProvider.llb\GDSIconEditor_CreateVIIcon.vi
Or if you download the OpenGDS (http://opengds.github.io/)
You can find the IconEditor here:
LabVIEW 20XX\resource\Framework\Providers\Open_GDS\ClassProviders\Common\IconEditor\GDSIconEditor_CreateVIIcon.vi
