Dan Bookwalter N8DCJ Posted December 16, 2014 Report Posted December 16, 2014 I have not messed with complex numbers in probably 30 years or more... I have a snippet of Matlab code that I need to wire up asap , I made a couple of feeble attempts and decided to ask the experts. I need a wiring soluition for this: exp(sqrt(-1)*angles) I assume it is pretty simple? TIA Dan Quote
crossrulz Posted December 16, 2014 Report Posted December 16, 2014 There is the complex data type. sqrt(-1) is just i. Quote
Biometrology Posted December 16, 2014 Report Posted December 16, 2014 Is this what you need? Treats your angle array as the imaginary component of a complex number (with a 0 real value component). Check out the help for Re/Im To Complex and Exponential Function. A. Quote
Mellroth Posted December 16, 2014 Report Posted December 16, 2014 (edited) On 12/16/2014 at 3:10 PM, Dan Bookwalter N8DCJ said: I need a wiring soluition for this: exp(sqrt(-1)*angles) Rewrite exp(i*v) to exp(i)^v, or in LabVIEW notation LabVIEW 2010: Complex rotation.viFetching info... /J Edited December 16, 2014 by Mellroth Quote
gb119 Posted December 16, 2014 Report Posted December 16, 2014 Orwire angle to a cos and sin function and then feed them both to a real amd imaginary parts to complex number (e^{i\theta}=\cos \theta + i \sin \theta) Quote
