1D array search implementation
kodon1
I need to implement some sort of a 'search 1D array' function, but only with simple functions.
This means that I can use loops and cases and other simple functions (numeric. boolean, comparison) but not much more than that.
The challenge that I'm facing is to create a smaller array out of a bigger one. I wasn't able to find a way up until now.
Hope that you'd have some ideas.
thanks
Use a FOR loop with a coniditional terminal.  Autoindex in the search array.  If the current item matches the search parameter, you stop your loop and pass out the data.
thanks.
so I stop the for loop when the first value is found, but then I want to keep searching the array... should I use some sort of an outer loop?
That is different requirements from the Search 1D Array.  If you want the all of the indecies that match, then still use the FOR loop, but use a conditional indexing output tunnel that is wired to the i terminal.  Your condition should be if the current item matches the lookup item.
ok. thanks for the tip.
when you say - 'conditional indexing output tunnel' is it a straight forward option of the for loop? I wasn't aware of that
Make an wire up the i to the right border of your FOR loop.  It should default to an indexing tunnel.  You can right click on that tunnel and select "conditional".  I think it came out in LabVIEW 2012.  Very useful tool.
  • 2 weeks later...
