Sharon_ Posted June 18, 2015 Report Posted June 18, 2015 Hi friends, Is it possible to access measurement studio parameters from LabVIEW?. I want to adjust my camera parameters and save the current values permanently. I mean what if I don't want to load the settings parameter from a file everytime ? Can it be done? Thanks for your time and support..!!! Thanks, -Sharon Quote
hooovahh Posted June 18, 2015 Report Posted June 18, 2015 I don't have IMAQ installed but I think those settings are exposed using various property nodes. I also remember those settings in MAX and saving them in MAX retained the values. So in the past I've just set it up in MAX and saved it, and never needed to change it for the application. Quote
Sharon_ Posted June 19, 2015 Author Report Posted June 19, 2015 On 6/18/2015 at 12:07 PM, hooovahh said: I don't have IMAQ installed but I think those settings are exposed using various property nodes. I also remember those settings in MAX and saving them in MAX retained the values. So in the past I've just set it up in MAX and saved it, and never needed to change it for the application. That's right. My application is like : 1. Adjust camera parameters-> 2. Run Sample OCR-> 3. If not Ok goto step 1 until OCR output is OK. So I am looking for the possibility of saving MAX settings from LabVIEW. Thanks, Sharon Quote
LogMAN Posted June 19, 2015 Report Posted June 19, 2015 On 6/19/2015 at 12:25 AM, Sharon_ said: That's right. My application is like : 1. Adjust camera parameters-> 2. Run Sample OCR-> 3. If not Ok goto step 1 until OCR output is OK. So I am looking for the possibility of saving MAX settings from LabVIEW. Thanks, Sharon Are you by chance searching for this: http://digital.ni.com/public.nsf/allkb/BBB5B94C038267DF8625723E00030559 Quote
