LittleRhitaMae Posted February 19, 2016 Report Posted February 19, 2016 i am encountering a problem regarding the create palette, there is no indicator, constant and control what i should i do ? thank you for answering Quote
hooovahh Posted February 19, 2016 Report Posted February 19, 2016 You selected a function not a terminal. What kind of control would you suggest it make? Right click a terminal (one of the inputs or outputs of a subVI) and then create the control/indicator/constant from that and it will make it for that data type. Same with a selected wire. 1 Quote
Aristos Queue Posted February 21, 2016 Report Posted February 21, 2016 Terminals are at the edges of nodes. You clicked in the middle of the node. Try again over one of the connection points. :-) 1 Quote
LittleRhitaMae Posted February 22, 2016 Author Report Posted February 22, 2016 thank you very much for answering my question Quote
