Fixed point multiplication in ASM
Neil Pate
Almost totally unrelated to LabVIEW, and is not really just a question more of just a ramble.
I have dusted off a PIC microcontroller that I have had lying around in my drawer for years, and am attempting to stop old-age brain rot my making it do stuff, but purposely limiting myself to assembler.
So far I have the (12-bit) ADC working, and sending the upper 8 bits back to the PC over RS-232 as an ASCII character.
Now all I want to do is display the analogue voltage on the PC. Should be simple. I am using the 5V supply as the reference, so a 12-bit ADC has a step size of 1.22 mV. Conversion from 12-bit hex value to human readable value should be reasonably straightforward: scale the ADC value by 1.22 mV, convert to say 5 digit BCD and chuck out over the serial port one character at a time. I figure the first step is to implement a fixed point multiplication, keeping things simple I can have the ADC reading as <+,16,0> and the scaling factor as <+16, 3>.
 This is the bit that is making my brain hurt... I have done some reasearch and it turns out that fixed point multiplication does not really care about the format of the number, only the bit-width. So you can use exactly the same algorithm to scale <+16,0> and <+16,3>. Anybody know if this is correct?
Now, I know I can take all sorts of shortcuts to get the ADC value in human readable format, I have decided for the purpose of the exercise I really want to figure this out using fixed point maths (I have no actual application in mind other than curiosity).
Correct :)
A few useful notes:
  • Your 16-bit fixed point number is stored in memory exactly like a 16-bit integer*.
  • Fixed point multiplication == Integer multiplication. The same algorithms apply to both.
  • The algorithms for integer multiplication don't depend on the value of the number. By extension, they don't depend on the representation of the number either.
    • e.g. Multiplying by 2 is always equivalent to shifting the bits to the left (assuming no overflow)
(* LabVIEW actually pads fixed point numbers to 64 or 72 bits, but I digress)
Anyway, to illustrate:
 Bit Pattern (MSB first) | Representation                | Value (decimal)
 0000 0010               | <+,8,8> (or equivalently, U8) | 2
 0000 0010               | <+,8,7>                       | 1
 0000 0010               | <+,8,6>                       | 0.5
 0000 0100               | <+,8,8> (or equivalently, U8) | 4
 0000 0100               | <+,8,7>                       | 2
 0000 0100               | <+,8,6>                       | 1
That's borderline blasphemy... ;) You can redeem yourself by getting LabVIEW involved:
Edited by JKSH
I did say "almost" :-)
This is the VI I knocked up just to test things out..
Thanks for the info, I will digest slowly tomorrow evening.
Edited by Neil Pate
Getting there slowly.. :-)
I have the 16-bit x 16-bit multiplication working using the 8-bit hardware multiplier.
Also I have fleshed out my LabVIEW demo to show how to solve the rest of my problem.
Convert (+,16,4) Fixed Point Number To String.vi
Convert First Decimal Place Of (+,16,4) Fixed Point Number To String.vi
Fixed Point Maths.vi
Edited by Neil Pate
