Why is indexing conditional tunnel 3x faster than shift registers
Indexing tunnels (conditional or not) follow a preallocation strategy of filling a larger-than-initially-needed array (later cutting the unneeded elements), while the “Build Array” primitive allocates a new array of exactly the right size on each iteration.  So there is a lot fewer calls to the memory manager with an indexing tunnel.
Link to post
Was aware of this but was not aware that this was also the case in initialize/replace scenarios.
More info on the subject here http://forums.ni.com/t5/LabVIEW/Why-is-indexing-conditional-tunnel-3x-faster-than-shift/m-p/3570173#M999382
Link to post
I thought build array did some preallocation but not very much. I rearranged the code with manual preallocation and you had to allocate thousands and thousands of elements for it to be faster.
I had a stray thought about allocating a percent of the existing array with a baseline and tried it out. For elements 0-10000 it allocates 1000 when it runs out, then for elements 10000+ its 10% of current array size. That made it about 30% faster than the indexing terminals. But, on the other hand, who cares in this situation? This use case doesn't seem like a big performance bottleneck.
Link to post
