thingsful Posted January 11, 2018 Report Share Posted January 11, 2018 Is there any way to make vi the same as LabVIEW's own functions, not only can not see the front panel ,but also can not see the back panel, like "+"or "-" function in Labview. Quote Link to comment
kaly2002 Posted January 11, 2018 Report Share Posted January 11, 2018 I have the same question Quote Link to comment
LogMAN Posted January 11, 2018 Report Share Posted January 11, 2018 (edited) When creating a source distribution you can remove the front panel and block diagram in the source file settings: Be aware that removing the block diagram prevents you from using the VI on a newer version of LabVIEW as it cannot be recompiled. Edit: You might find this article helpful: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LY1SAM Edited January 11, 2018 by LogMAN Quote Link to comment
hooovahh Posted January 11, 2018 Report Share Posted January 11, 2018 If you are looking to protect your IP you can apply a block diagram password. Hackers have ways of defeating them but it will keep out the majority of developers from copying your code. 1 Quote Link to comment
kaly2002 Posted January 11, 2018 Report Share Posted January 11, 2018 (edited) @LogMAN Thank you very much! The program is ok, but the icon is missing. Edited January 11, 2018 by kaly2002 Quote Link to comment
kaly2002 Posted January 11, 2018 Report Share Posted January 11, 2018 @hooovahhThank you! Quote Link to comment
LogMAN Posted January 12, 2018 Report Share Posted January 12, 2018 18 hours ago, kaly2002 said: The program is ok, but the icon is missing. Yes, I can see how that could be an issue. Unfortunately I'm not aware of a solution to fix the icon. The standard functions like Addition, Subtraction, etc... are not really VIs. They are written in C or whatever language they use to program LV nowadays. So, they can do stuff we can't. Quote Link to comment
kaly2002 Posted January 13, 2018 Report Share Posted January 13, 2018 On 2018/1/12 at 5:54 PM, LogMAN said: Yes, I can see how that could be an issue. Unfortunately I'm not aware of a solution to fix the icon. The standard functions like Addition, Subtraction, etc... are not really VIs. They are written in C or whatever language they use to program LV nowadays. So, they can do stuff we can't. it‘s so bad。 But thank you very much! Quote Link to comment
