trigger on a sequence of two sequential Boolean events
OK, this is kind of weird but I am new.. I am trying to trigger on a sequence of two Boolean events A,B, but these events are not active at the same time. And I cannot use a panel button to latch, and then release.
If A, and then B, activate Trigger=T, reset.
Ignore cases:
B then A,
B, then B,
or A then A.
Can I do this with shift registers..or a better idea?
I have tried a conditional case in a conditional case?
Id suggest looking at the section "State Machine Design Pattern" here:
The details will vary, but it sounds like this is what you want.
This tool may help, again depending on the details:
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-State-Diagram-Toolkit/ta-p/3606081
Its basically lets you model the state machine and it will script out the (boilerplate parts of the) code diagram for you.
Edited by smithd
I would try an "Action Engine" here.
https://forums.ni.com/t5/LabVIEW/Community-Nugget-4-08-2007-Action-Engines/td-p/503801
Edited by pallen
