bjustice Posted November 24, 2018 Report Share Posted November 24, 2018 X-POST to NI forums. (No luck there so far.) https://forums.ni.com/t5/LabVIEW/button-with-different-size-text/m-p/3864798/highlight/false#M1095147 I am hoping to determine if there is a programmatic method to have a button with boolean text with varying font size/color. This is achievable with a strong control using text selection end/start. Booleans expose these same properties in the property node... but it doesn't appear to do anything. Even more interesting is that I can copy/paste text with varying color/size into the boolean text... and it will work. Thoughts? Thanks! bool_text.vi Link to comment
Michael Aivaliotis Posted November 25, 2018 Report Share Posted November 25, 2018 Seems like a LabVIEW bug. Link to comment
bjustice Posted November 26, 2018 Author Report Share Posted November 26, 2018 Darn. Thanks for looking! Link to comment
Benoit Posted November 27, 2018 Report Share Posted November 27, 2018 Well I have been one step further... it can apply the color to all, but report an error... It it definitively a bug. Benoit Link to comment
bjustice Posted November 27, 2018 Author Report Share Posted November 27, 2018 Benoit, thanks for looking at this with me. It looks like the error that you generated there is a result of the "Vertical Arrangement" property not being allowed to be applied to boolean text. I get the following possible reasons for that error: So, this is good proof that not everything in the "text property palette" is compatible with boolean text. Which is fine, but the text select end/start should return a similar error in order to indicate the lack of support. Also, as I said earlier, I can copy/paste text into the boolean text and have it retain properties. Which means that the property node interface simply doesn't appear to support programmatic interaction. Link to comment
Benoit Posted November 27, 2018 Report Share Posted November 27, 2018 It's what we call a bug. You should report it. Benoit Link to comment
paul_cardinale Posted December 13, 2018 Report Share Posted December 13, 2018 There's a similar (and probably related) bug when setting boolean text attributes manually: If you select a portion of the boolean text, then use the Font menu to change something (e.g. the color), it will change all of the text, not just the selected part. This bug showed up sometime around LV2008; it was fixed in one of the later versions; then it was un-fixed, and we still have it today. You can get around it by making floating text and setting it the way you want, then cut-and-paste into the boolean text. (I haven't tried programmatic cut-and-paste; maybe that would work.) Link to comment
bjustice Posted January 24, 2019 Author Report Share Posted January 24, 2019 Interesting history. Thanks for the information. I've reported this to NI. I will post here if they generate a CAR thanks everyone Link to comment
bjustice Posted January 30, 2019 Author Report Share Posted January 30, 2019 CAR created: Reference ID 726196. Link to comment
Please sign in to comment
Sign In Now
