Joshwa Posted May 15, 2019 Report Posted May 15, 2019 Hello, I am a .dll that act as interface with my HID device and Windows API. I am a problem to open a connection with my device using the CLFN. But if i run the example, that is made with VC++, that is provided from the Author of the .dll, the function return me the error code: "Device not Found" The function and prototype in the DLL is: FT260_STATUS FT260_OpenByVidPid(WORD vid, WORD pid, DWORD deviceIndex, FT260_HANDLE* pFt260Handle) FT260_STATUS is an enum that i defined it as uint8 enum in labview This is how I configured the CLFN: uint8_t FT260_OpenByVidPid@16(uint16_t Vid, uint16_t Pid, uint32_t DeviceIndex, uint32_t* SessionID) Convenction call is: stdcall (WINAPI) Can someone help me to understand what is the problem? Thank you very much Quote
hooovahh Posted May 16, 2019 Report Posted May 16, 2019 I'm not a HID device expert (Rolfk maybe?), but there seems to be several DLL wrappers to talk to HID devices, but the best solution is to use NI-VISA and talk to it over USB Raw. For this you'll need to make your own INF driver using the NI-VISA Driver Wizard (should be installed with NI-VISA). Then install that driver for your device instead of the one from Microsoft (Device Manager). For this in Windows 8 and newer you'll need to disable driver verification. Then the device shows up in MAX, and the Help >> Find Examples and searching VISA Raw will show some examples. http://www.ni.com/tutorial/4478/en/ https://forums.ni.com/t5/LabVIEW/Nugget-1-of-n-GEtting-started-with-USB-communication-via-VISA/td-p/743518 https://forums.ni.com/t5/LabVIEW/Nugget-2-of-n-USB-Control-transfers-using-VISA/td-p/757011 If you can't or won't use VISA then there are lots of other DLL wrappers but I haven't found one that works as well as VISA with custom driver. http://ahidlib.com/pages/programming_labview.php?lang=en (license needed for full?) https://forums.ni.com/t5/Example-Programs/Windows-API-HID-Functions-Enumeration/ta-p/3513868 https://forums.ni.com/t5/LabVIEW/Confusion-between-HID-and-VISA-communication/m-p/1741390#M610130 https://forums.ni.com/t5/LabVIEW/Need-Example-Code-to-Interface-with-a-USB-HID-compliant-Device/m-p/2763516#M814451 https://forums.ni.com/t5/LabVIEW/How-to-configure-the-call-library-function-using-a-dll-for-HID/m-p/2757194#M813218 https://www-user.tu-chemnitz.de/~heha/mb-iwp/Durchflussmesser/ Quote
Rolf Kalbermatter Posted May 22, 2019 Report Posted May 22, 2019 On 5/15/2019 at 5:18 PM, Joshwa said: Hello, I am a .dll that act as interface with my HID device and Windows API. I am a problem to open a connection with my device using the CLFN. But if i run the example, that is made with VC++, that is provided from the Author of the .dll, the function return me the error code: "Device not Found" So when you run the VC++ example you get an error! Well that is hardly LabVIEW related isn't it? You must make sure that you pass the right VID (vendor ID) and PIC (product ID) as programmed in the chip. The chips should come with a default VID and PID from FTDI but it can be changed by a utility from FTDI. Check in the Windows device manager for your interface and in the driver settings you can see the VID and PID values, but they are in hexadecimal notation. Quote
