JimPanse Posted August 20, 2019 Report Posted August 20, 2019 Hello, experts, in the current description of the NI Vision Acquisition Software it says: http://www.ni.com/pdf/manuals/375130k.html Deprecated Features ◾NI - IMAQ 19.0 .... ◾Removed support for LabVIEW Real-Time targets running Phar Lap ETS OS Will the OS Labview Real Time (Phar Lap ETS OS) be discontinued and is there an alternative based on Linux? a good time Jim Quote
smithd Posted August 21, 2019 Report Posted August 21, 2019 (edited) cRIO is all linux, PXI now supports linux: https://www.ni.com/product-documentation/55164/en/ Edited August 21, 2019 by smithd Quote
JimPanse Posted August 21, 2019 Author Report Posted August 21, 2019 This means that RT Linux for Desktop PC is theoretically possible. Can I buy a Linzens from RT Linux for Desktop PC´s? And how long will Pharlab ETS be available? Quote
hooovahh Posted August 21, 2019 Report Posted August 21, 2019 There is several efforts on getting the Linux RT virtual machine working with a few methods of success. I don't have the spare hardware or time to see if it is possible but I too suspect you can get the Linux RT OS on a desktop. My own concern is there is no support, and potentially the licensing issue. Quote
JimPanse Posted August 22, 2019 Author Report Posted August 22, 2019 I could imagine that RT Linux from a PXI system also works on a PC. This will certainly not be allowed by licensing law. Quote
JimPanse Posted August 22, 2019 Author Report Posted August 22, 2019 Is it possible to make Windows 10 realtime capable, so that i can use Vision? Quote
Rolf Kalbermatter Posted August 22, 2019 Report Posted August 22, 2019 (edited) 5 hours ago, JimPanse said: I could imagine that RT Linux from a PXI system also works on a PC. This will certainly not be allowed by licensing law. It most definitely does with some caveats such as what hardware your computer may use. As to licensing, NI has so far mostly avoided the answer, but from the reaction so far it is clear that they don't feel compelled to create a standalone version of NI Linux for PCs. As far as licensing is concerned, the NI Linux part itself is a no brainer, it is Linux after all and you are always allowed to rebuild that for whatever hardware you want. The more interesting part is the NI-VISA, NI-this and NI-that software and of course the LabVIEW real-time engine that you also need to have installed on such a system to be useful for targeting with LabVIEW Realtime. This clearly is NI owned software and unless you have an explicitly spelled out license that allows you to use it on such a system, you are simply violating NI copyrights if you copy any of these files to a NI Linux operated platform of your own (aside that there are technical issues such as ABI compatibility and CPU architecture/family, for instance not every ARM CPU core is able to execute the LabVIEW ARM compiled modules, you need a Cortex A or compatible CPU core, this is the more powerful type compared to Cortex M or R which are meant for deeply embedded devices or reliable security platforms, or pre Cortex era cores). Edited August 22, 2019 by Rolf Kalbermatter Quote
Rolf Kalbermatter Posted August 22, 2019 Report Posted August 22, 2019 3 hours ago, JimPanse said: Is it possible to make Windows 10 realtime capable, so that i can use Vision? Vision doesn't require realtime at all. What are you really trying to do here? Quote
JimPanse Posted September 5, 2019 Author Report Posted September 5, 2019 It is about an image processing where the result is a parameter for a control. Here I need a real-time in the range of 1 ms. Quote
