EErock Posted January 9, 2020 Report Posted January 9, 2020 When routing data out of a for or While loop, indexing is usually selected. A Simple LEFT-Click in the actual tunnel node should select the next (Last Value) and better yet, keep selecting the next available option (Concat, Conditional) (there are only 4) This would be a big time saver as 90% of the time when you don't want' indexing', you want 'Last Value' MUCH less cumbersome than 2 menus deep right click selections. Same logic as older one-click True-False Slider constants. "One Click Nodes" Quote
jacobson Posted January 9, 2020 Report Posted January 9, 2020 You can post it to the idea exchange if you want but I would see this making it hard to normally select the tunnel (just to move it around) for everyone using the auto-tool. Quote
hooovahh Posted January 10, 2020 Report Posted January 10, 2020 I get your point of the multi menu setting isn't very quick to change. That being said I sometimes mess around with conditional outputs, and with arrays I might be concatenating, or conditionally concatenating, or indexing, or last value, or conditionally last value. And I just think cycling through all 6 possible combinations would be more annoying than a couple right clicks. Quote
