Thang Nguyen Posted June 19, 2020 Report Posted June 19, 2020 I need to display the engineer string in a tree so I used number to engineer string. The issue is it is very limited to format the engineer string with this function. Look at below example I want only one digit number before the decimal point but I don't know how to set that. Please let me know how to do it. Thank you in advance. Quote
Neil Pate Posted June 19, 2020 Report Posted June 19, 2020 Aren't engineering strings always multiples of 3 digits? You cannot have an engineering string 1.2x10E10,it will be 12x10E9 Maybe I misunderstood the question. if you want advanced string formatting you can use the format to string function, it allows a very flexible formatting string. Sorry on mobile now or would put some pics. Quote
Thang Nguyen Posted June 20, 2020 Author Report Posted June 20, 2020 I want 1.2ex10 not 12.0ex9 as you can see in my example. I will check format into string. Quote
Neil Pate Posted June 20, 2020 Report Posted June 20, 2020 2 hours ago, Thang Nguyen said: I want 1.2ex10 not 12.0ex9 as you can see in my example. I will check format into string. Yes but that is no longer Engineering formatting which is where the confusion is coming in. Format into string should be able to give you what you want, I will put an example shortly. Quote
Neil Pate Posted June 20, 2020 Report Posted June 20, 2020 (edited) Is this what you want? I still don't really understand the subtleties of all the different scientific vs floating point formats and normally just play around until I get what I want. I find going into the Advanced numeric formatting is a huge help as it basically tells you the exact formatting string to use. Especially useful for timestamps! Edited June 20, 2020 by Neil Pate 1 Quote
Thang Nguyen Posted June 20, 2020 Author Report Posted June 20, 2020 @Neil: Yes, this is what I need. Thank you very much. Quote
