Create custom "Method override" window
kosist90
Dear all,
I was asking this question also on NI forum, but didn't get answer yet (https://forums.ni.com/t5/LabVIEW/Create-custom-quot-Method-override-quot-window/m-p/4075683). Let me ask the same question here.
Is there a way to customize "Method override" window, to include there some more features (like proposed here , for example)? I was checking this library (C:\Program Files (x86)\National Instruments\LabVIEW 2020\resource\Framework\Providers\LVClassLibrary\NewAccessors\MemberVICreation.lvlib) and found method CLSUIP_CreateOverride.vi (C:\Program Files (x86)\National Instruments\LabVIEW 2020\resource\Framework\Providers\LVClassLibrary\NewAccessors\CLSUIP_CreateOverride.vi). But it seems, that this is not the one which calls dialog window.
I do not want to change override logic, just would like to add more features to window which allows to select the VI to override. So I'm curious, whether this is possible - or better would be to implement custom Project Provider for that...
Thanks a lot in advance!
I don't think this window is available as VI. It is probably one of those built-in windows. Even if it isn't, you'll probably be better off doing your own tool. The recreation of the current override VI generation shouldn't be very complicated, and you could use anything available in MemberVICreation.lvlib to save some work. Project Provider for it is really just a quality-of-life addition, your tool will work as well (or even better :D) with a simple class selector drop-down list.
  • Thanks 1
I agree, the window is most likely built-in so there is no way to change it. Not sure if this is useful, but there is a way to customize the behavior of the override retooler:
https://forums.ni.com/t5/LabVIEW/Use-of-MUST-OVERRIDE/m-p/3286047/highlight/true?profile.language=en#M960301
This could be useful if you want to change the general outcome of the override operation (i.e. add an error case, remove the Call Parent function, etc.).
Edited by LogMAN
  • Similar Content
    • By odoylerules
      All,
      Recently I moved from SVN to GIT as my source control and revision manager.  I'm still getting used to everything so i don't consider myself an expert yet, but i really missed the Project Provider options that I used for SVN source control within the project window.
      I'm releasing an open source beta project provider for TortoiseGit Integration.  This addon is very similar to the current SVN options but was developed entirely from scratch.  Currently this provider requires TortoiseGit to perform most of the Source Control Actions.  I know a lot of you on here have recently switched to sourcetree, however, unlike TortoiseGit they do not currently offer a command line interface yet for windows that i could find.  I've tried to make this project flexibile and if they offer a command line for windows eventually it should be fairly quick to re-factor for that.
      The project can be found here: https://bitbucket.org/jed_d/lv_tortoisegit
      Addon Features
      Tortoise Git Icon Overlays within Labview IDE Tortoise Git Commands from within Labview IDE Ability to directly reload a project from within the Project Window, as well as prompts to reload the project when performing actions that require a reload. Open Git Bash from project window
      I'm hoping some of you will have a chance to try this out and let me know of any issues.  I would like to track issues on bitbucket if possible so that they are all in one place, but i will also be checking these post for issues as well.
      Feel free to fork the project and hack on it yourself.  If you come up with something decent and don't mind sharing, send a pull request.
      One initial issues i'm hoping the community can help with is building the package for older versions of LV.  Currently i only have access to 2013 so i am only able to build the package for this version.  If anyone has a change to pull down the repo and build it for older versions please do.
      Another question i have for the community is the license i currently have on the project.  This is my first open source project of any kind so i wasn't sure what license to put on it.  I did not want to be too restrictive so i went with a BSD license.  If any of you see an issue with this please let me know as I'm open to suggestions.
    • By John Lokanis
      I have a class that defines a message.  I inherit from this class for all my messages.  The class contains a must override method called 'Execute'.  Every time I create a child of this class and create the override method for Execute then go to save it, it wants to save the parent as well.  This only occurs after I create the override method for Execute.  If I just create the class, save it, change its inheritance and save it again the parent class is not affected.
      I have no idea why it is doing this but it is really annoying.  Especially since everything is in version control, I end up having to check the parent out just to save the project.
      The reason given for the need to save the parent is 'Item moved within library'.
      The parent class is in a lvlib.
      I am running LV 12.0f3.
      Any ideas?  Is there a CAR for this or am I just doing something wrong?
      thanks,
      -John
