eberaud Posted April 15, 2021 Report Posted April 15, 2021 I've been asked to escalate the issue related to CAR 185890 where text that should normally be interpreted as ASCII suddenly starts being interpreted as Unicode, which means the text is replaced by random Chinese characters. It seems like this CAR has been opened for 10 years now. I found some NI forums related to this, but nothing on LAVA. So I'd love to know if you also still experience this really pervert bug. It's hard to reproduce, it usually occurs after weeks of running our application (executable). Note that in my case, I do have some text (mostly control captions) that is Unicode on purpose so we can localize it, and this works fine. But the rest (table and listbox content in particular) is always displayed as ASCII and works fine most of the time, expect when LabVIEW decides to suddenly interpret EVERYTHING on the front panel as Unicode. Most of what I could find about this is from 2010-2013, so it would be nice to see what people experience about this in 2021 Quote
ensegre Posted April 15, 2021 Report Posted April 15, 2021 (edited) VIPM 2017 on Ubuntu 18. Don't know if related to that CAR, but jibberish chinese anyway + very ugly fonts. Edit: quick search, I found this: https://forums.ni.com/t5/LabVIEW/Why-does-my-LabVIEW-occasionally-display-in-Chinese/m-p/1545242#M571786. Now my VIPM 2017 appears to be based on rte2015, and the closest to what suggested in that post is /usr/local/lib/LabVIEW-2015/English/lvapp.rsc - which in my case is present, no *.tmp in that directory instead. Edited April 15, 2021 by ensegre Re: about old workaround Quote
Mads Posted April 16, 2021 Report Posted April 16, 2021 (edited) I have seen this a couple of times in my applications and a fix then has always been to either remove all but English, or support all languages on the run-time languages page in the application builder (perhaps any change there is what is really doing the trick, I have not explored that as I have always just moved on when the error disappeared). Edited April 16, 2021 by Mads Quote
eberaud Posted April 19, 2021 Author Report Posted April 19, 2021 Thanks ensegre and Mads. I think the CAR related to what you two talked about is CAR 202900. Unfortunately I don't think this applies to my problem. Quote
MzazM Posted November 1, 2021 Report Posted November 1, 2021 Same issue for me. VIPM2017 and LV2020 on Ubuntu 20.04. no tmp files and .rsc file exists. Jibberish chinese and ugly fonts. I havent found workaround yet. Quote
ensegre Posted November 15, 2021 Report Posted November 15, 2021 Zyga posted a solution for the linux font problem (probably not the CAR referred to, as Manudelavega wrote): Quote
