paul_cardinale Posted May 19, 2021 Report Posted May 19, 2021 View File Y Controls Support - Version 2.0.2.0 Installer.zip Installs support for Y Controls. Requires LabVIEW 2019 or later. Submitter paul_cardinale Submitted 05/19/2021 Category General LabVIEW Version Not Applicable License Type BSD (Most common) 2 Quote
paul_cardinale Posted June 15, 2021 Author Report Posted June 15, 2021 I've discovered a bug. It appears to be a bug in LabVIEW. Here is what I believe is happening: Hiding inside each instance of a Y Control is an instance of "C: ... \LabVIEW xxxx\resource\plugins\Y Control\Ability Manager\Y Control Ability Manager.XCTL". When LabVIEW loads an instance of a Y Control that depends* upon another Y Control, there are 2 instances of "Y Control Ability Manager.XCTL" that need to be initialized: One for the outer Y Control and one for the inner Y Control. The "Init" ability of the Xctl for the inner Y Control gets called first, and it works OK. However when the "Init" ability is called for the outer Y Control, it is passed the wrong refnum: Instead of getting the refnum to the instance of the Xctl in the outer Y Control, it gets a refnum to the instance of the Xctl in the inner Y Control. *In my case this happens because I have a Y Control calls a dialog VI that contains a reference to a VI that has a Y Control. 1 Quote
paul_cardinale Posted June 17, 2021 Author Report Posted June 17, 2021 After a lot of digging, I found the bug (in my code). It wasn't happening just when one Y Control depended on another, but whenever two different types of Y Control were both in memory. The fix is attached. I've also done a bit of cleanup (including closing a dangling VI ref), and some minor improvements of the help. It's backward compatible; no need to rebuild anything, just run the new installer. Y Controls - Version 2.0.3.0 Source.zip Y Controls Support - Version 2.0.3.0 Installer.zip Quote
Sparkette Posted January 28, 2022 Report Posted January 28, 2022 When I click "Go" on the YControl wizard, LabVIEW just sits there seemingly forever, all the while logging this error every second: <DEBUG_OUTPUT> 01/27/22 11:52:33.767 PM DWarn 0xFCC058F4: An item recompiled in the final iteration should not still have recompile needed set: [VI "Y Control Isolators and Misc.lvlib:Insert Info In Error.vim" (0x000000000a5b12a0)] /builds/labview/2021/source/compiler/compiler.cpp(643) : DWarn 0xFCC058F4: An item recompiled in the final iteration should not still have recompile needed set: [VI "Y Control Isolators and Misc.lvlib:Insert Info In Error.vim" (0x000000000a5b12a0)] [ExecSys:0; NOT InExec] </DEBUG_OUTPUT> 0x00000000006D9611 - <unknown> + 0 0x00007FFFF6DDB5F5 - _ZNK11DebugStream7ProcessEv + 25 0x000000000064D329 - <unknown> + 0 0x000000000064D991 - <unknown> + 0 0x000000000064E1B8 - <unknown> + 0 0x0000000001D14136 - <unknown> + 0 0x0000000001D15369 - <unknown> + 0 0x0000000001D18333 - <unknown> + 0 0x0000000001D1AC85 - <unknown> + 0 0x0000000001DB393D - <unknown> + 0 0x0000000002032563 - WSendEvent + 253 0x00000000020339A4 - <unknown> + 0 0x0000000001F6BABD - <unknown> + 0 0x0000000001F658F8 - <unknown> + 0 0x0000000000608599 - <unknown> + 0 0x00000000006087A8 - <unknown> + 0 0x00007FFFF6802B25 - __libc_start_main + D5 0x00000000006069F9 - <unknown> + 0 I'm using LabVIEW 2021 Community Edition on Linux. Quote
X___ Posted July 24, 2022 Report Posted July 24, 2022 (edited) On 6/17/2021 at 10:20 AM, paul_cardinale said: After a lot of digging, I found the bug (in my code). It wasn't happening just when one Y Control depended on another, but whenever two different types of Y Control were both in memory. The fix is attached. I've also done a bit of cleanup (including closing a dangling VI ref), and some minor improvements of the help. It's backward compatible; no need to rebuild anything, just run the new installer. Y Controls - Version 2.0.3.0 Source.zip 1.97 MB · 9 downloads Y Controls Support - Version 2.0.3.0 Installer.zip 1.79 MB · 8 downloads If I open the content of the "Installer.zip" file, it appears to be missing the "Install Y Control Support.vi", "UNInstall Y Control Support.vi" and "Installer READ ME.txt" that you had in the 1.x version in that thread. If I copy those items in the Pure G Installer version 2 and run install, things seem to work fine. For some reason, the help file is showing a TOC but the content appears blank (same for version 1 BTW, so it might be something related to my installation in LV 2021 SP1 64 bit/Windows 10). Edited July 24, 2022 by X___ Quote
X___ Posted July 25, 2022 Report Posted July 25, 2022 OK the Help file not showing its content is courtesy of MS. Simply "unblock" the chm file using Properties, 'cause: "The file came from another computer and might be blocked to help protect this computer" Quote
