Union c in labview
I have to create a library that has as input the pointer to this structure
unsigned char
Type
unsigned int  Len
union {
   unsigned char   Raw [EFIUDS_MSG_MAX_DATA_SIZE]
   struct {
      unsigned char   SI
      unsigned char   PARAM [EFIUDS_MSG_MAX_DATA_SIZE-1]
   }   REQUEST
   struct {
      unsigned char   PR_SI
   }   POSITIVE_RESPONSE
   struct {
      unsigned char   NR_SI
      unsigned char   SI
      unsigned char   NRC
   }   NEGATIVE_RESPONSE
Data
how do i implement the labview?
thank you
Pass a U8 array of length EFIUDS_MSG_MAX_DATA_SIZE
Unions are syntactic sugar for a single piece of contiguous memory. You'll just have to figure out how to interpret the data.
Ok,
thank You!
