Can't Update the Firmware of a Newly Purchased cRIO (Update Firmware Button Missing)
smarlow
Just got a cRIO-9047 out of the box.  I am running LabVIEW 2020 SP1 on the host computer, and the cRIO is running firmware 6.1.0f2 (why so old for a device that just shipped?).  We ordered this controller/chassis months ago, but delivery was delayed, supposedly due to the chip shortage.  The host computer is running CompactRIO 21.0 drivers.  When I try to install the latest software (anything newer than 'legacy'), the installer tells me I need to update the firmware on the controller to version 7 first.  However, when I select the device in MAX, the 'Update Firmware' button that is supposed to be on the System Settings tab is missing.  I have 4 sbRIOs on the same subnet, and they are all good (Update Firmware button showing, running newer, non-legacy software loads).  When I run the legacy installer for 20.5, and try to use the 'Update BIOS' button on the installer dialog box, I get a dialog saying the host has no new firmware load higher than the one installed, even though I am running the latest CompactRIO drivers.  Has anyone else had this problem?  Without a solution, I can only run the legacy software load.  Thanks for any help.
Have you tried updating the firmware via the web interface of the controller?
Edited by Mads
  • 1 month later...
  • 3 years later...
What is the port that needed to be unblocked? I can see the Update Firmware button on mine but I keep getting error codes and the firmware won't install. Error code 800407E2 and code 80040390.
The first error code might be due to lack of privileges, try running NI max as admin...Or a full disk (try reformatting the cRIO first).
As for ports to open if blocked
https://forums.ni.com/t5/Real-Time-Measurement-and/Cannot-access-cRIO-behind-NAT-firewall-with-MAX/td-p/1868251
