Popular Post sam Posted July 7, 2022 Popular Post Report Posted July 7, 2022 (edited) I've been surprised today with one of the LabVIEW's most useful functions (imo) which I use all the time. After so many years and only now seeing this behavior/feature. I thought I share it 🙂 I've always used an empty array of N-Dim for my desired type input. only to accidently find out today that I can also use a scalar for the type.  ha!  Edited July 7, 2022 by sam 3 4 Quote
X___ Posted July 9, 2022 Report Posted July 9, 2022 On 7/7/2022 at 12:06 PM, sam said: I've been surprised today with one of the LabVIEW's most useful functions (imo) which I use all the time. After so many years and only now seeing this behavior/feature. I thought I share it 🙂 I've always used an empty array of N-Dim for my desired type input. only to accidently find out today that I can also use a scalar for the type.  ha!  But if you provide a string that should be interpreted as a 1D array, and chose "create indicator", the created indicator is a 2D array: Try to force the output to be 1D by connecting a 1D array indicator, and you get a broken wire: In other words, it seems that if you want a non 2D output, you need to specify the type. BTW, in the first diagram above, the 2D array output contains a single row, so the string is properly decoded (ignore the missing format string). Bonus: did you know that if you set the expected type to be 1D (and obviously the output to be 1D), a "2D" string will be cast to 1D?  Quote
infinitenothing Posted July 20, 2022 Report Posted July 20, 2022 Good tip. I hate type guessing. I'm looking at you TDMS Pallet. Quote
