Francois Aujard Posted November 15, 2022 Report Posted November 15, 2022 Hello, I have a mystery, why this Vi (red with sick written on the inside) which has the same connector and data input type is not compatible with the others? I started from an empty VI, and copy the code. I also tried to start from a Vi that is compatible and replace the code (not the commands)... but nothing to do, as soon as I connect it to the board, the wires break. Do you have an explanation? best regards Quote
Francois Aujard Posted November 15, 2022 Author Report Posted November 15, 2022 No the "Sick Vi" is not reentrant. For information : "Instru Vi" is reentrant with partaged copy "NI Vi", "Virtuel Vi" and "Instr Vi" are not reentrant "LFT Vi" is reentrant with preallocated copy Quote
bjustice Posted November 15, 2022 Report Posted November 15, 2022 check to make sure that the input terminals are the same setting as well: "required, recommended, optional." This matters 1 Quote
Francois Aujard Posted November 15, 2022 Author Report Posted November 15, 2022 Thank very much @bjustice, I was sure I had checked 😵... but apparently not, that's my problem ! I'm sorry to have been so bad on this one... I'm going to stop drinking 🥴... Quote
hooovahh Posted November 15, 2022 Report Posted November 15, 2022 6 minutes ago, Francois Aujard said: I'm going to stop drinking 🥴... Hey let's not get hasty now. But honestly this has bitten me on a few occasions as well, so don't feel bad. 2 Quote
