bjustice Posted March 1, 2023 Report Posted March 1, 2023 This is a cross-post from the darkside: https://forums.ni.com/t5/LabVIEW/LV-2021-thick-line-decoration-changed/m-p/4280737 After a month, I didn't get any hits there though, so reposting here in hopes that someone might have insight. In LabVIEW 2021, the thick line decoration changed to include aliasing. This is a total bummer for me. I use this line for drawing fluid lines, and the aliasing makes the fluid lines fuzzy, which is not a desire for me. If anyone here might have any idea how to create or get back a 3-pixel width line without aliasing, you would be my friend. Quote
ShaunR Posted March 1, 2023 Report Posted March 1, 2023 (edited) I've no idea if they introduced an an ini setting for aliasing or a real solution for this but a classic, flat, square, button can be collapsed to 5px and, if you make the border transparent (which is 1px), it looks like a 3px line. However it won't do arbitrary angles-horizontal and vertical only. You may have to rethink how you display your fluid with either the picture control or jpg/png images copy and pasted to the FP, if it's a real issue. I'm not sure how you are using to display a fluid (reveal behind a progress bar?). I've never used decorations as they are so limited. Edited March 1, 2023 by ShaunR 1 Quote
bjustice Posted March 1, 2023 Author Report Posted March 1, 2023 oh wow, I had not even considered using a flat box with a transparent border. That does indeed create a 3 pixel, non-aliased line. It's a bit clunkier than I would like, but it does get me exactly what I need with respect to creating something that is effectively equivalent to the pre-2021 thick line. That unblocks me for now. I might contact NI though and make a bit of a fuss. Maybe they can add a thick line back into LabVIEW on a hidden palette without aliasing. grumble grumble Quote
ShaunR Posted March 1, 2023 Report Posted March 1, 2023 1 hour ago, bjustice said: Maybe they can add a thick line back into LabVIEW on a hidden palette without aliasing Maybe an option on the right-click menu? Quote
Popular Post dadreamer Posted March 8, 2023 Popular Post Report Posted March 8, 2023 On 3/1/2023 at 10:35 PM, ShaunR said: I've no idea if they introduced an an ini setting for aliasing They introduced a token for smooth lines: SmoothLineDrawing=False 2 2 Quote
ShaunR Posted March 8, 2023 Report Posted March 8, 2023 37 minutes ago, dadreamer said: They introduced a token for smooth lines: SmoothLineDrawing=False That works. Thanks. Quote
