dipanwita Posted May 24, 2023 Report Posted May 24, 2023 I have a H&H PLI Series Electrical Load in my laboratory. I am targeting to control this device by giving instruction using LABVIEW. Currently, as a interface medium I am using ethernet (LAN) for communication. I have downloaded specific driver (H&H PLI series) required for this device to use in LabVIEW. I am facing some difficulties in it such as providing SCPI commands which is in manual to this device but not receiving response from it. I need some help to resolve this matter. I am not able to understand the issue. I need some help. delta2.vi Quote
Rolf Kalbermatter Posted May 24, 2023 Report Posted May 24, 2023 2 hours ago, dipanwita said: I have a H&H PLI Series Electrical Load in my laboratory. I am targeting to control this device by giving instruction using LABVIEW. Currently, as a interface medium I am using ethernet (LAN) for communication. I have downloaded specific driver (H&H PLI series) required for this device to use in LabVIEW. I am facing some difficulties in it such as providing SCPI commands which is in manual to this device but not receiving response from it. I need some help to resolve this matter. I am not able to understand the issue. I need some help. delta2.vi 37.21 kB · 2 downloads So you say you downloaded a driver but program the entire communication in plain calls anyhow. Why that? First thing would be that commands need to be terminated. Try to add a \n or maybe \r\n to the *IDN? command too. Also, while the case of the commands usually shouldn't matter for SCPI command, you do not need to write the syntax from the programming manual literally. The convention is, that the uppercase letters are required (short form), while the lowercase letters are optional (long form). Some instruments allow partial optional characters and other only understand either the exact short form or the full long form command parts in a single command. One potential problem is that the native TCP nodes only have 4 messages modes for TCP Read. And neither is usually perfect for normal instruments. You would want to use the termination character mode, but there is only the option to use CR AND LF. Many instruments send either one of them but not necessarily all of them. Standard mode kind of still works but the Read will timeout as it can't read the actually asked amount of characters. This will slow down your communication a lot. Better is usually to go and use VISA instead for these cases. Quote
Phillip Brooks Posted May 30, 2023 Report Posted May 30, 2023 (edited) I'm guessing that you are new to LabVIEW. It appears that you found your driver on the NI site (http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E962513CF06C2315E0440021287E6E02) and followed this link: You probably installed the driver, but then skipped down to the bottom and followed the link on how to use Ethernet to control your instrument. Those instructions are for the case where the instrument driver doesn't exist or failed to download. You missed the part in the middle (step 7) to look for and USE the driver. The driver I found looks very clean and should work as a starting point for you. You will need to learn the basics of LabVIEW. I would suggest that you start on the NI site for new user help. NI has dedicated resources to support new users. LAVA is a LabVIEW related site, but the name stands for LabVIEW Advanced Virtual Architects. Beginning questions are not likely to receive much help... Edited May 31, 2023 by Phillip Brooks Quote
codcoder Posted May 31, 2023 Report Posted May 31, 2023 If you haven't already I suggest that you install Wireshark on your computer. This will allow you to analyze the ethernet traffic and help you debug. As a disclaimer I am sure there are many other well-suited communication analyzers but Wireshark is the default tool for me. Quote
