Dan Bookwalter N8DCJ Posted June 29, 2024 Report Posted June 29, 2024 OK , i do not actually have the hardware yet ,i am using simulated so a little tough to test it out , i suppose i could use different ranges on each channel to try to figure it out .. anyway , if I configure a task to use channels , in say this order , 1,7,3,6 .... will I get the data back in 1,7,3,6 or 1,3,6,7 ? TIA Dan Quote
Neil Pate Posted June 29, 2024 Report Posted June 29, 2024 Will be in the order you specify the channels, so 1,7,3,6 Quote
mcduff Posted June 29, 2024 Report Posted June 29, 2024 You may not be able to specify the channels in any order you want. If I recall correctly for some DAQs you can only specify them in ascending order. Not sure if this holds true for simulated instruments. Quote
Neil Pate Posted July 1, 2024 Report Posted July 1, 2024 On 6/29/2024 at 9:55 PM, mcduff said: You may not be able to specify the channels in any order you want. If I recall correctly for some DAQs you can only specify them in ascending order. Interesting! I never actually tested my assumption. Quote
