Serial Read
Hi everyone,
I've got a multimeter with a RS232 output. I would like to see the data send by this device in my LabVIEW program.
I made a program with: "Serial Port Init.VI", "Bytes at Serial Port.VI" and "Serial Port Read.VI".
When I run the program, I get no errors, but I don't receive any data out of my multimeter!! :( And it keeps on running waiting for some input I think.......
If you've got solution or just some comment, please tell me!
Thanks. Cheers,
Joost
First of read you must write a query command, for example read? or fetch? or data?; in sequence is first init.vi, after write with a string command query, the bytes at serial port and the read.vi, you can insert the write-bytescount-read in a while loop, and remember in the out of loop close with close visa.vi
I hope this useful for you.
sorry for bad english.
Hi everyone,
Thanks. Cheers,
Joost
Oke! My program is working. I still don't know why:
When I connect my RS232 cable into my multimeter the program doesn't receive data (but is running). When I connect pin 2 of my RS232 cable to pin 2 of my multimeter my program receives data!!! :blink:
I still have to find out what's going on........
  • 1 month later...
I suggest you to use a oscilloscope to capture the data, instead of DMM.
Joost,
If connecting Pin 2 to 2 works, then you probably need a "straight" serial cable, as opposed to a null-modem serial cable where the RX and TX pins are crossed.
Regards,
-Khalid
