How programmatically fire the "panel close?" event ?
With the exception of "Application Exit" (in Lv8.2) and user defined events, no events of the Event Structure can be triggered programmatically. If a panel is closed programmatically, that does not fire a Panel Close event. This is important for VIs that filter the panel close event, then do some clean up work and then close their own panels (or do the same on behalf of another VI). Similar applies to Value Changed (where the value gets changed, and in the event code the value is somehow modified [perhaps pinned to be within a certain range] ). The system breaks down if the programmatic work triggers events.
App Exit was added as an exception predominantly because it *can't* trigger itself (once LV is exiting, its exiting!) and it provides a way for VIs to guarantee a time to do their clean up work (such as resetting hardware) for built applications.
With the exception of "Application Exit" (in Lv8.2) and user defined events, no events of the Event Structure can be triggered programmatically...
Except that we do have the capability to fire the Value Change event programmatically. Sure, we have to select the right property first, but it can be done, so why shouldn't we be able to have another option for that method called "Fire event?" and choose to use it when WE want to?
BTW, I'm not saying this should be done, just that it could be done and that it might not be a bad idea. Since we can't use a user event in the same case as a filter event and since (presumably) the loop would stop after the case executes, this doesn't leave users with much of a choice for how to do this programmatically other than duplicating their cleanup case.
Thanks for clearifying.
Well I think it is theoretically possible (correct me if I'm wrong)
But what if you use a win32.dll call to close the window? I think this will trigger the event! (Win only offcourse and not pure G)
Ton
