Michael Aivaliotis Posted December 24, 2006 Report Posted December 24, 2006 I wanted to know if it's possible to create nested properties with XControls. See the built-in boolean properties as an example. Also, how do we create custom help so that when someone hovers over the custom XControl property node you can see help in the floating help window? Quote
Ton Plomp Posted December 24, 2006 Report Posted December 24, 2006 So Michael asking questions. First the easy one: Use the description: The container state contains the reference to the xcontrol The second one looks more difficult, but fortunately not: And here is some proof: The help text is just the string, which originates from the numeric-data in a standard X Control Now, Michael what are you going to do with this. Hopefully a way to build an Xcontrol which has all the properties of normal LV controls, and this build with scripting? Ton Quote
Michael Aivaliotis Posted December 25, 2006 Author Report Posted December 25, 2006 I'll clarify my question a bit more since your answer is not what I was looking for. If you open up the one and only Xcontrol example which ships with LabVIEW, you will see a custom property called: Fahrenheit Mode? Notice that it does not have any Context Help. How do we add help to this specific property? Now, you can add as many custom properties or methods as you desire. However, you can't add them in a nested fashion I hope this clarifies what I'm after. Quote
Aristos Queue Posted December 25, 2006 Report Posted December 25, 2006 Michael_Aivaliotis said: I'll clarify my question a bit more since your answer is not what I was looking for. If you open up the one and only Xcontrol example which ships with LabVIEW, you will see a custom property called: Fahrenheit Mode? Notice that it does not have any Context Help. How do we add help to this specific property? I can't help with the nested properties question, but on the Context Help, I think you just set the Description for the VI that implements that property. Whatever is in that description shows up as the help for the XControl's property node. Quote
Michael Aivaliotis Posted December 25, 2006 Author Report Posted December 25, 2006 Aristos Queue said: ...on the Context Help, I think you just set the Description for the VI that implements that property. Whatever is in that description shows up as the help for the XControl's property node.I tried that but it had no affect. Quote
Jeffrey Habets Posted December 25, 2006 Report Posted December 25, 2006 Aristos Queue said: I can't help with the nested properties question, but on the Context Help, I think you just set the Description for the VI that implements that property. Whatever is in that description shows up as the help for the XControl's property node. Michael, You can set the context help for properties and methods in an XControl from the XControl properties dialog. Quote
Michael Aivaliotis Posted December 25, 2006 Author Report Posted December 25, 2006 Jeffrey Habets said: You can set the context help for properties and methods in an XControl from the XControl properties dialog. That worked. Thanks. Quote
LAVA 1.0 Content Posted December 25, 2006 Report Posted December 25, 2006 Your question Michael reminds me of one XControls related question of mine that still is unasnwered. Is there a way to inherit properties and methods of build-in LabVIEW control to the properties of an XControl at least in a case where XControl front panel consits of only one built-in control. The idea would be to extend the functionality of built-in control in a much a same fashion as one can extend functionality of a OOP class. I haven't found a way to inherit these build-in properties and methods but maybe some LAVA readers have... Quote
Jeffrey Habets Posted December 26, 2006 Report Posted December 26, 2006 jimi said: Your question Michael reminds me of one XControls related question of mine that still is unasnwered. Is there a way to inherit properties and methods of build-in LabVIEW control to the properties of an XControl at least in a case where XControl front panel consits of only one built-in control. The idea would be to extend the functionality of built-in control in a much a same fashion as one can extend functionality of a OOP class. I haven't found a way to inherit these build-in properties and methods but maybe some LAVA readers have... This was for me also the first feature I searched for when the XControl was introduced. Saddly it appeared not to be possible. It would indeed be nice to have this feature in the future for at least the XControls that have only one native control embedded. For now, as a kind of workaround I just create a read property for the embedded native control's reference, which at least gives some kind of flexibility without having to re-implement common properties/methods. Quote
Michael Aivaliotis Posted December 27, 2006 Author Report Posted December 27, 2006 Jeffrey Habets said: as a kind of workaround I just create a read property for the embedded native control's reference, which at least gives some kind of flexibility without having to re-implement common properties/methods.This is the same solution I have come to as well. The problem however with exposing a reference to the end user is that this breaks encapsulation rules. There is the potential of messing around with elements that you want protected. I don't have a problem with re-creating certain properties. If only we could group related properties and use nesting then it would be one step closer. As it stands, you end up with a super long property list. Quote
Ton Plomp Posted December 27, 2006 Report Posted December 27, 2006 Sorry I answered the wrong question, but if you look at how the original properties/methods are implied true inheritance is used. Using the AllProps property of a string, there is no such property label.text or caption.text. Just two references of the type 'Text', Is there a way for use to mimic this? Ton Quote
Ton Plomp Posted January 2, 2007 Report Posted January 2, 2007 Just a status update (or what have you done in the holidays?) I can generate the first generation properties (read and write) (so just visible, label.text and othere subclasses not yet, though they are not that difficult) I can add them (in some way) into the XControl, allthough I have mayor issues with the state typedef. My vit uses another one than the xcontrol and won't accept the new one.... I cannot generate the Methods (haven't looked int it) Hopefully this friday I'll have it sorted out about the property creation into the XControl... Ton Quote
Ton Plomp Posted January 3, 2007 Report Posted January 3, 2007 Okay: here it is the dynamic generation of XControl properties. This first alpha version is somewhat limited: You need a special state format (actually it needs a XCTL array of control references You need a special facade vi (see the time-out case Only creation of properties Only creation of first generation properties (eg. label.text won't work, though they are selectable) No feedback about created properties You'll only know the program is done because the mouse is normal again.... No instructions beside these... The Program: and a template XControl: disconnect from library.viFetching info... Here is a screenshot: After starting select an XControl with Select XControl, then select the controls, then select the properties. The generation is then done. You can open the XControl by using openXControl. Some Bugs: Sometimes saving everything inside the xcontrol, and closing it totally will fix the xcontrol Yes Crelf, it is not really CR ready material Ton Quote
Michael Aivaliotis Posted January 9, 2007 Author Report Posted January 9, 2007 I'd like to post an update to this thread. Yes, there is indeed a way to create so called "pull-right" properties for XControls. Someone from NI informed me of a way that is not officially supported by them but none-the-less works. All you need to do is change the localized long name of the property to include the nesting. For Example: If you have a property called My New Nested Property 1 and you want the menu to appear like Mike->My New Nested Property 1, set the Localized Long Name to Mike:My New Nested Property 1. Colon is used as the separator. Further experimenting reveals you can also create line seperators by replacing the name completely with a hyphen "-". Of course, this means you lose access to the property since now it's not selectable. You would probably create dummy properties to support this. Quote
Jeffrey Habets Posted January 9, 2007 Report Posted January 9, 2007 Michael_Aivaliotis said: I'd like to post an update to this thread. Yes, there is indeed a way to create so called "pull-right" properties for XControls.Someone from NI informed me of a way that is not officially supported by them but none-the-less works. All you need to do is change the localized long name of the property to include the nesting. For Example: If you have a property called My New Nested Property 1 and you want the menu to appear like Mike->My New Nested Property 1, set the Localized Long Name to Mike:My New Nested Property 1. Colon is used as the separator. Ah, I actually was looking in the right direction for this.. I tried construct like Mike|NestedProp and Mike->NestedProp, but that didn't work. Obviously I didn't try the so obvious :. :thumbdown: Anyway, good work! :thumbup: Quote
Aitor Solar Posted March 15, 2007 Report Posted March 15, 2007 QUOTE(Michael_Aivaliotis @ Dec 27 2006, 08:10 AM) Quote This is the same solution I have come to as well. The problem however with exposing a reference to the end user is that this breaks encapsulation rules. There is the potential of messing around with elements that you want protected. Well, you can protect XControl's properties and methods, like you protect a library VI so VIs belonging to other libraries can't use them. Now, does that mean the end user won't see the protected properties and methods? Unfortunately, it seems not. The user will see the protected properties and methods... but will get an error if he tries to run them . Saludos, Aitor Quote
