Vladimir Drzik Posted March 30, 2007 Report Posted March 30, 2007 Hi guys I am using a reentrant VI which has several clones dynamically created through Open VI Reference. I would like to open the FPs of all those clones for debugging purposes (most of the time it is enough for me to have a look at what the FPs display). I know I can do the clone FP opening programmatically, but can I do it from the IDE once my application is already running? Vladimir Quote
Bobillier Posted March 30, 2007 Report Posted March 30, 2007 QUOTE(Vladimir Drzik @ Mar 29 2007, 05:26 PM) Hi guysI am using a reentrant VI which has several clones dynamically created through Open VI Reference. I would like to open the FPs of all those clones for debugging purposes (most of the time it is enough for me to have a look at what the FPs display). I know I can do the clone FP opening programmatically, but can I do it from the IDE once my application is already running? Vladimir Hi vladimir I'm not sure that you can do that, because it's not sure than the clones have front panel too. Try with this small tools find on NI site Regards Quote
Neville D Posted March 30, 2007 Report Posted March 30, 2007 QUOTE(Vladimir Drzik @ Mar 29 2007, 08:26 AM) Hi guysI am using a reentrant VI which has several clones dynamically created through Open VI Reference. I would like to open the FPs of all those clones for debugging purposes (most of the time it is enough for me to have a look at what the FPs display). I know I can do the clone FP opening programmatically, but can I do it from the IDE once my application is already running? Vladimir Why dont you make the clone VI's re-entrant and then make the re-entrant VI "open front panel when called". That way all instances will automatically open up at run-time. If you dont want some of them open, just close the window (it wont stop the VI from running). The only issue with this method is that its hard to figure out which instance is which. Neville. Quote
Vladimir Drzik Posted March 31, 2007 Author Report Posted March 31, 2007 QUOTE(Neville D @ Mar 29 2007, 07:38 PM) Why dont you make the clone VI's re-entrant and then make the re-entrant VI "open front panel when called". That way all instances will automatically open up at run-time. If you dont want some of them open, just close the window (it wont stop the VI from running).The only issue with this method is that its hard to figure out which instance is which. Neville. Yes of course I can do that. But I just don't want the four windows to pop up every time I run my application. I need them only in case my application is running and there seems to be something going wrong. Vladimir Quote
Jim Kring Posted March 31, 2007 Report Posted March 31, 2007 Here's an article that I just wrote that might have some information related to your issue: Thinking in G >> Reentrant VI Clone Name Hope you find it useful. Quote
