I am doing project and I need ur advice in some thing , I am using LV 8 and I want that program to be run in any machine even if there is no labview i.e exceteable file!! can I do that???
To run your programs on a machine without LV installed, you need to have the LabVIEW run-time engine installed. If you have the application builder installed you can create an installer by adding build settings to your project.
You should really start by searching these things first. Searching the LV help or the internet for "executable" would really give you all the answers you need.
