Thang Nguyen Posted May 1, 2007 Report Posted May 1, 2007 Hi, I have a project working with S7-300 PLC of Siemens. The requirement is reading out data inside the PLC using Ethernet. After doing some research I have the 2 options: Modbus TCP/IP and OPC server. The price of modbus TCP/IP for PLC is about $3,500.00 and the price for OPC is about $550.00. This is the reason I choose OPC protocal for this project. With OPC server, I have two options: shared variable and data socket. I have still not worked with both of them, so I don't have any experience about it. Do you have any recommend for em, which one I should use? Thank you so much, Thang Nguyen Quote
David Wisti Posted May 2, 2007 Report Posted May 2, 2007 Just wondering, how are you going to get the S7-300 to communicate Modbus TCP? Were you going to use the Siemens FB OPEN MODBUS / TCP Library? (2XV9450-1MB00-0YE0) I have used datasockets in the past only because it was well before shared varibles were created (Lv7.0). If a shared variables can be an OPC client without the DSC module, I would go that route. Shared variables seem much simpler than datasockets but I have never connected them to an OPC server. Quote
Thang Nguyen Posted May 2, 2007 Author Report Posted May 2, 2007 QUOTE(dwisti @ Apr 30 2007, 06:01 PM) Just wondering, how are you going to get the S7-300 to communicate Modbus TCP? Were you going to use the Siemens FB OPEN MODBUS / TCP Library?(2XV9450-1MB00-0YE0) Thank you for your answer. You are right, I intend to use the MODBUS/TCP 2XV9 450-1MB00 Quote
i2dx Posted May 2, 2007 Report Posted May 2, 2007 QUOTE(Thang Nguyen @ Apr 30 2007, 11:57 PM) Do you have any recommend for em, which one I should use? I don't really have a recommendation, because I only had one project at all where I had to communicate with a SPS, but I used LV 7.1.1 and a OPC Server with DATASOCKET and it worked fine. This combination is fast enough and reliable, so if I had to do this again, I'd use OPC/Datasocket again ... I encountered a bug in the Datasocket VIs of LV 7.1: I was not able to keep more than 5 Writing Datasocket connecitons open simultanously, because then LV crashed and frezed the PC. But when I was working with datasocket attatched controls I had no problems at all. The reason why I was trying to keep the connections open simultanously was, that the initialisation was rather slow (about one second ...) Quote
Thang Nguyen Posted May 2, 2007 Author Report Posted May 2, 2007 Hi, Do you know any LabVIEW driver for S7-300? Quote
i2dx Posted May 2, 2007 Report Posted May 2, 2007 QUOTE(Thang Nguyen @ May 1 2007, 04:42 PM) Hi,Do you know any LabVIEW driver for S7-300? no, sorry ... Quote
David Wisti Posted May 2, 2007 Report Posted May 2, 2007 QUOTE(Thang Nguyen @ May 1 2007, 10:42 AM) Hi,Do you know any LabVIEW driver for S7-300? The only open-source way I know is http://libnodave.sourceforge.net/index.php' target="_blank">libnodave. You might be able to use the win32 dll with Labview. Quote
Karl Rony Posted May 3, 2007 Report Posted May 3, 2007 I wasn't pleased with the performance of LabVIEW's standard OPC client capabilities in version 7.1. I didn't want to use the DSC module either. I went with www.opcware.com. I haven't tested LabVIEW 8.2's standard OPC client capabilities yet. Quote
