LAVA 1.0 Content Posted May 30, 2007 Report Posted May 30, 2007 Hi all, I'd like to record a RS 232 signal to disk so as to be able to regenerate it (to simulate a device), the RS 232 speed is 57600 Baud. I read that I should over-sample at least 16x if I go for a Analog Input board because RS needs steep rising edges. Has anybody ever done something similar ? Does it work ? I have never used HS DIO (655x or 656x series), maybe this would be more appropriated to record and regenerate an RS 232 signal ? Any comment, ideas, though or orientation will be very appriciated, thanks in advance. Quote
Grampa_of_Oliva_n_Eden Posted May 30, 2007 Report Posted May 30, 2007 QUOTE(TiT @ May 29 2007, 11:09 AM) Hi all,I'd like to record a RS 232 signal to disk so as to be able to regenerate it (to simulate a device), the RS 232 speed is 57600 Baud. I read that I should over-sample at least 16x if I go for a Analog Input board because RS needs steep rising edges. Has anybody ever done something similar ? Does it work ? I have never used HS DIO (655x or 656x series), maybe this would be more appropriated to record and regenerate an RS 232 signal ? Any comment, ideas, though or orientation will be very appriciated, thanks in advance. It has been years and NI no longer makes the board ... Re:over-sampling... The chips (when last I looked) do X10 over-sampling themselves so to do it correctly would required even more over-sampling. If they want to look a tht rise time response then ingore the data transfer rates and look at it as an anlog signal and do the Nyquist math. Ben QUOTE(Ben @ May 29 2007, 11:49 AM) It has been years and NI no longer makes the board ... Re:over-sampling... The chips (when last I looked) do X10 over-sampling themselves so to do it correctly would required even more over-sampling. If they want to look a tht rise time response then ingore the data transfer rates and look at it as an anlog signal and do the Nyquist math. Ben I have also used a "ESCC-PCI" from Commtech to do this type of work. It gave me the flexibility do send bad packets. Of course the FPGA stuff should allow similar results these days. Ben Quote
peteski Posted June 7, 2007 Report Posted June 7, 2007 QUOTE(TiT @ May 29 2007, 11:09 AM) Hi all,I'd like to record a RS 232 signal to disk so as to be able to regenerate it (to simulate a device), the RS 232 speed is 57600 Baud. I read that I should over-sample at least 16x if I go for a Analog Input board because RS needs steep rising edges. Has anybody ever done something similar ? Does it work ? I have never used HS DIO (655x or 656x series), maybe this would be more appropriated to record and regenerate an RS 232 signal ? Any comment, ideas, though or orientation will be very appriciated, thanks in advance. TiT, I have a couple of quick comments (I've been swamped recently, not much time to contribute to this forum, unfortunately!) Beware of the voltage levels on the RS-232, if this is a "standard" RS-232 device! (and standard can be a very difficult term to apply to RS-232!) I've measured voltages of +/- 11 volts using an oscilloscope. If you use a standard DIO at TTL levels, you may need some circuitry or a box to properly handle the mismatch between TTL and RS-232 levels. BTW, why not just listen using the computer's RS-232 port and copy down the byte stream to a file, then spit that file back through the RS-232 port when you want to simulate? It might be faster, better, and cheaper that way. Is there something particularly "interesting" you expect to need to do that an RS-232 port may not quite be able to facilitate? -Pete Liiva Quote
