LabVIEW tools cursor is the Arrow even when other tools are selected
Has anyone else experienced the (LabVIEW 2024 on Windows 10) tools cursor stuck as the Arrow even when other tools are selected? I can still wire, but it is annoying. This started happening after playing with some sub-panel examples. I've restarted LabVIEW, rebooted windows, and recovered an older LabVIEW.ini file (just in case a setting got changed). The issue persists on just one computer out of 5 with the same set-up. Any ideas?
16 minutes ago, Neil Pate said:
That is weird. No sorry not seen that before!
So you have tried manually changing the tool?
I have manually and automatically changed the tools. The various tools still work, but there is no visual indication that the tool changed other than they still work if you ignore the cursor appearance.
