Youssef Menjour Posted September 21, 2025 Report Posted September 21, 2025 Here’s the message ready to copy-paste into the forum: Title: Enabling XNode development in LabVIEW 2020 – .ini flags Hello everyone, I’m trying to enable XNode development mode in LabVIEW 2020 64-bit. So far, I’ve added the following keys to my LabVIEW.ini file: Xnodewizardmenu=True XnodewizardMode=True XTraceXnode=True XNodeDebugWindow=True SuperSecretPrivateSpecialStuff=True XNodeDevelopment=True XNodeDevelopment_LabVIEWInternalTag=True I’m sure this is the correct .ini file because the XNodeWizardMenu does appear when I right-click on a VI (for example on Match Regular Expression.vi). However, in the Project Explorer the New menu does not show XNode (below XControl), which I was expecting. My questions are: Is there an additional .ini key required in LabVIEW 2020 to make New → XNode appear? Can someone explain what each of these flags actually activates? Has anyone managed to get the Project Explorer “New → XNode” option visible in LabVIEW 2020? Thanks! Quote
hooovahh Posted September 22, 2025 Report Posted September 22, 2025 As mentioned in the crosspost, NI has a special license for allowing XNode creation through the Project Explorer. To get around this I developed the XNode Editor. Quote
