Reading Homewizard P1 meter API v2
Tom Eilers
I have a Homewizard P1 meter, from which I want to read only the power in Watt with LabView. There API version 2 see: https://helpdesk.homewizard.com/en/articles/5935977-integrating-energy-with-other-systems-api uses HTTPS. They have an example to read the P1 with curl (curl https://<IP ADDRESS>/api/measurement --insecure -H "Authorization: Bearer EXAMPLE-TOKEN". With system exec I can read the P1 meter values. My question is it possible to do this in pure LabView HTTP Get/Set and Header vi's and How. In my case I use url:  https://192.168.178.109/api/measurement --insecure -H "Authorization: Bearer 010183D11FD0A5F08990D911BBFF3995"
P1 meter API v2.vi
--insecure is a curl argument. You don't need to include that in the headers.
You can do the equivalent of --insecure by setting verify server to False when creating the HTTP session.
Should never do this. Anyone can sit between you and the server and decode all your traffic. The proper way is to add the certificate (public key) to a trusted list after manually verifying and checking it.
What's the point of using HTTPS if you are going to ignore the security?:frusty:
