Connector Pane of Property Node
QUOTE(Eugen Graf @ Aug 29 2007, 11:09 AM)
Hello, does anybody know, why Instr. property node has the output on the top side ?
Eugen
You sure this isn't just an auto-wiring problem? If you move the property node up until it aligns with the wire, it should exit to the right.....
Shane.
QUOTE(shoneill @ Aug 29 2007, 12:39 PM)
Shane.
Yes, you are right. But why this auto-wiring problem?
Eugen
QUOTE(Eugen Graf @ Aug 29 2007, 04:01 AM)
Bizarre. Does that happen with all the new Instr property nodes you drop on the block diagram, too, or just that one (and maybe copies of it)?
QUOTE(Justin Goeres @ Aug 29 2007, 08:37 AM)
This is slightly OT but is seems related.
I noticed durring some execution highlighting that a "To More Specific" node got highlighted with a border that gave me the impression the "To More..." was just a VI with a small icon.
I am wondering if the "To More ..." (and many other operations) are really being implemented with X-nodes, a LV version of slight-of-hand.
Ben
If I create a new it doen't more happen.
If you open the BD of the VISA Configure Serial Port.vi and copy the Property node inside them to your BD, then you will get this comic behaviour.
Eugen
I'm assuming that you are seeing this is in LV 8.0?
QUOTE(Eugen Graf @ Aug 29 2007, 06:04 AM)
Confirmed on my machine (LV85):
http://forums.lavag.org/index.php?act=attach&type=post&id=6797''>http://forums.lavag.org/index.php?act=attach&type=post&id=6797'>http://forums.lavag.org/index.php?act=attach&type=post&id=6797
Note that the property node on the BD of VISA Configure Serial Port.vi does not immediately appear to exhibit the behavior, but if you delete the VISA resource name output wire it, in fact, has its terminal coming out the wrong way, too.
QUOTE(LV Punk @ Aug 29 2007, 07:30 AM)
Hehe... I like Brian's almost paranoid closing to that blog:
"I still look back over my shoulder to see if I've missed something, but I'm confident that "serpdrv" won't be coming back."
But maybe, just maybe.... :unsure:
