Eugen Graf Posted August 30, 2007 Report Share Posted August 30, 2007 Hello, does anybody know, why Instr. property node has the output on the top side ? Eugen Link to comment
shoneill Posted August 30, 2007 Report Share Posted August 30, 2007 QUOTE(Eugen Graf @ Aug 29 2007, 11:09 AM) Hello, does anybody know, why Instr. property node has the output on the top side ?Eugen You sure this isn't just an auto-wiring problem? If you move the property node up until it aligns with the wire, it should exit to the right..... Shane. Link to comment
Eugen Graf Posted August 30, 2007 Author Report Share Posted August 30, 2007 QUOTE(shoneill @ Aug 29 2007, 12:39 PM) You sure this isn't just an auto-wiring problem? If you move the property node up until it aligns with the wire, it should exit to the right.....Shane. Yes, you are right. But why this auto-wiring problem? Eugen Link to comment
Justin Goeres Posted August 30, 2007 Report Share Posted August 30, 2007 QUOTE(Eugen Graf @ Aug 29 2007, 04:01 AM) Yes, you are right. But why this auto-wiring problem? Bizarre. Does that happen with all the new Instr property nodes you drop on the block diagram, too, or just that one (and maybe copies of it)? Link to comment
Grampa_of_Oliva_n_Eden Posted August 30, 2007 Report Share Posted August 30, 2007 QUOTE(Justin Goeres @ Aug 29 2007, 08:37 AM) Bizarre. Does that happen with all the new Instr property nodes you drop on the block diagram, too, or just that one (and maybe copies of it)? This is slightly OT but is seems related. I noticed durring some execution highlighting that a "To More Specific" node got highlighted with a border that gave me the impression the "To More..." was just a VI with a small icon. I am wondering if the "To More ..." (and many other operations) are really being implemented with X-nodes, a LV version of slight-of-hand. Ben Link to comment
Eugen Graf Posted August 30, 2007 Author Report Share Posted August 30, 2007 If I create a new it doen't more happen. If you open the BD of the VISA Configure Serial Port.vi and copy the Property node inside them to your BD, then you will get this comic behaviour. Eugen Link to comment
orko Posted August 30, 2007 Report Share Posted August 30, 2007 QUOTE(Eugen Graf @ Aug 29 2007, 04:01 AM) Yes, you are right. But why this auto-wiring problem? I'm assuming that you are seeing this is in LV 8.0? Link to comment
Eugen Graf Posted August 30, 2007 Author Report Share Posted August 30, 2007 QUOTE(orko @ Aug 29 2007, 03:05 PM) I'm assuming that you are seeing this is in LV 8.0? Link to comment
Justin Goeres Posted August 30, 2007 Report Share Posted August 30, 2007 QUOTE(Eugen Graf @ Aug 29 2007, 06:04 AM) If you open the BD of the VISA Configure Serial Port.vi and copy the Property node inside them to your BD, then you will get this comic behaviour. Confirmed on my machine (LV85): http://forums.lavag.org/index.php?act=attach&type=post&id=6797''>http://forums.lavag.org/index.php?act=attach&type=post&id=6797'>http://forums.lavag.org/index.php?act=attach&type=post&id=6797 Note that the property node on the BD of VISA Configure Serial Port.vi does not immediately appear to exhibit the behavior, but if you delete the VISA resource name output wire it, in fact, has its terminal coming out the wrong way, too. Link to comment
LAVA 1.0 Content Posted August 30, 2007 Report Share Posted August 30, 2007 Confirmed here too, happens on 8.0, 8.20 and 8.5. I checked VISA Serial Break in these versions and saw the 'regular' behavior for the property nodes. LV versions 6.1, 7.0 and 7.1 do not appear to have this 'irregular' behavior. Might this have something to do with la mort du Serpdrv? Link to comment
orko Posted August 30, 2007 Report Share Posted August 30, 2007 QUOTE(LV Punk @ Aug 29 2007, 07:30 AM) Might this have something to do with http://openmeas.blogspot.com/2007/02/la-mort-du-serpdrv.html' target="_blank">la mort du Serpdrv? Hehe... I like Brian's almost paranoid closing to that blog: "I still look back over my shoulder to see if I've missed something, but I'm confident that "serpdrv" won't be coming back." But maybe, just maybe.... Link to comment
Please sign in to comment
Sign In Now
