OpenG "File Locate in Project" tool v1.0 released
Jim Kring
Hello Everyone,
There is a new OpenG tool called "File Locate in Project" library (ogedit_file_locate_in_project) available. This package adds a File>>Locate in Project option to the LabVIEW menu. When you select this menu option from the menu of a VI's Front Panel or Block Diagram, the VI will be highlighted in the Project Explorer window.
post-17-1189897331.png?width=400
See here for more info.
You can download+install this and other OpenG libraries using VI Package Manager.
Orko and Jim, thanks for this simple but useful tool! I also learned something new by examining the tools. I didn't know how to add items to the file menu... :) Thanks again!
QUOTE(Michael_Aivaliotis @ Sep 16 2007, 11:15 PM)
Would be perfect if it had a keyboard shortcut.
Unfortunately, there is no way to assign a keyboard shortcut to a dynamically added menu-item (e.g., those menu options that appear because you add a menu-launch VI to the wizard, project, or help folder). I tried filing this as a bug during a beta, a while back, but it was rejected :( Maybe I should try re-submitting it as a feature request.
QUOTE(Jim Kring @ Sep 17 2007, 08:13 AM)
Sun of a gun. I just checked... You CAN assign a shortcut key. :thumbup:
QUOTE(Michael_Aivaliotis @ Sep 17 2007, 08:52 AM)
Now just restart LabVIEW and see if the shortcut still works. :headbang:
I've assigned File>>Locate in Project... to Ctrl+Shift+E, which is not assigned to anything and is very similar in behavior to Ctrl+E for toggling between Front Panel and Block Diagram (when selected from a VI) and for toggling between Items view and Files view (when selected from the Project Explorer)
Hmmm... this shows up in LabVIEW.ini as the following:
CustomShortcuts=";APP_WIZARDS,Ctrl+Shift+E"
It appears that that the Custom Shortcuts is only available for the first item, alphabetically, in the wizard folder -- this is the "APP_WIZARDS" item. For example, I have a "Rename Folder of VIs..." option that is not even shown in the Custom Shortcuts dialog.
QUOTE(tcplomp @ Sep 17 2007, 09:13 AM)
Yes, you are right. This must be one of the meanest pranks NI has played on us. :nono: "Hey look, I can assign shortcut keys"... "oh, wait, they're gone" HaHaHa, fooled ya suckas!
QUOTE(dsaunders @ Sep 17 2007, 09:11 AM)
Yep, I found that out http://forums.lavag.org/Homing-a-front-panel-t8947.html&view=findpost&p=34914' target="_blank">just recently. :angry:
You may also notice that the "Open..." item in the menu shortcut selection list is where this "bug/feature" slipped in.
