Enable/Disable & Show/Hide Controls
Kelly
I've had several VIs to hide and/or show and enable and/or disable controls and indicators on the front panel. After some discussion on Info-LabVIEW I cleaned them up and combined them. Here are two VIs. One will disable, disable & gray, or enable selected controls on the front panel of the VI it is used in. The other will hide or show (make invisible or visible) selected controls on the front panel of the VI it is used in. Documentation is on the front panel of these VIs as well as in the description of each control/indicator.Kelly Berschpost-15024-0-09707300-1352416824.jpgpost-11742-0-78664400-1352474562_thumb.pI should have included the fact that these VIs are for LabVIEW 8.2.Kelly
QUOTE(kbersch @ Oct 30 2007, 11:19 PM)
Nice Work!
  • 8 months later...
I've updated my Show/Hide and Enable/Disable controls VIs so they recursively find control refnums. This allows them to now find controls in Tabs and Clusters. You will need to make sure no two clusters/tabs have identically named controls or this will affect all of them.
There are two more VIs along with these because they are used in the recursive search. They are modified versions of the "Get controls on tabs.vi" written by Dave A. Graybeal. All four VIs need to be in the same folder. These VIs were written with LabVIEW 8.5.1.
QUOTE (kbersch @ Oct 30 2007, 06:19 PM)
Kelly,
I'd be interested in checking out your VIs, but I only go up to LV8.0. Any chance that you could save to 8 and post them?
Thanks.
I did a little more testing and found a bug in the two support files. Here they are with the fix.
Kelly, relying on control labels is something I generally find potentially dangerous. A more robust method would be using the control references directly. You can see a quick example here (in 7.1, if memory serves). In actual code, I would probably separate the action from the group input, but it shows the concept well enough.
  • 10 months later...
Great work Kelly. I have used your earlier version (before the cluster and tab controls were added. However, how do you generate the list of controls?
Roy
I don't want to burst your bubble on some of your code but you should checkout the VIs in
C:\Program Files\National Instruments\LabVIEW 8.6\vi.lib\Utility\traverseref.llb
there are two top level VIs that allow you to farm an array of all references of any type of LV object w/out worrying about traversing structures yourself.
In the end your code would still do the same thing, but be more robust and flexible for different types.
