Webcam without need for NI Vision?
does anyone of you know if it is possible to set up live webcam image aquisition
without the need for the expensive NI Vision addon? (maybe using activeX?)
(I am planning to buy the Labview Base system)
Thank you!
Jasper
QUOTE(zappa2 @ Oct 31 2007, 09:24 PM)
The Hytek Automation toolkit is pretty damn comrephensive for $399. If all you want to do is acquire and display, I agree that NI-IMAQ for USB Cameras is the way to go, or you might want to try Pete Perente's drivers - they're old and unsupported, but might do what you want with a bit of twiddling.
QUOTE(crelf @ Oct 31 2007, 02:53 PM)
Thnx Crelf,
but I tried installing NI-IMAQ for USB Cameras and it keeps asking for NI Vision or the Vision Assitant that needs to be installed first.
So can't even install Ni-IMAQ for USB Cameras.
But maybe there is a way around this?
ZITAT(crelf @ Oct 31 2007, 02:53 PM)
@crelf: NO, we already had the discussion about NI-IMAQ for USB (see link below).
NO, noway around.
As already quoted in the link above (http://forums.lavag.org/index.php?showtopic=8441&view=findpost&p=32005) the NI-IMAQ for USB cameras will only work together WITH the Vision toolkit.
The IVision library will work with most USB-webcams. Give it a try, the download is free, and it will run for sometime.
Jens
ZITAT(Karissap @ Oct 31 2007, 11:27 PM)
I created this example in the code repository USB continuous acquire I used a Logitech webcam. At the time when I created it I didn't have the vision toolkit, I only used the free IMAQ drivers and the free NI IMAQ for USB drivers.
Interesting. Unfortunately my experience is completely different. Currently I do have installed LV8.2.1, which comes with NI-IMAQ-driver version 3.7.1. Still I cannot install the NI-USB-driver without the VISION package (as it is also stated on NI.com). Perhaps you had a version, where it was possible, but the current version always requires the NI Vision package to be installed.
Jens
