Hi everybody!!!
I am working in a remote application with LabVIEW 8.0. I have a serius problem if a client hasn't install the LabVIEW 8.0 Run time engine.
How can I ensure from HTML or PHP that the LabVIEW 8.0 run time engine was installed?
Do you know a way to install sillently the LabVIEW 8.0 run time engine in a client pc via HTML or PHP?
Thanks a lot!!!!!!!!!!!!!!!!!
Looking at the NI forum I see that older version of the run-time engine can be installed silently using this command.
lvrteinstall.exe /q
Not sure if this works for the newer ones. If it doesn't I recommend using a scripting language (like AutoIt3) to run the installer, and press the return character until the installer starts.
I don't know of a method to check for run-time engines using html or php.
QUOTE(akala @ Nov 14 2007, 06:19 PM)
I doubt it, it would be a very risky situation if this could be done
QUOTE(hooovahh @ Nov 14 2007, 07:26 PM)
lvrteinstall.exe /q
The quiet install still works (in 8.5)
Ton
QUOTE(akala @ Nov 14 2007, 12:19 PM)
No way with any recent OS! The ability to start any executable remotely through a HTTP connection is exactly what all Adware, Malware and other suspect programmers would like to have. A system that allows that will be invested with these kind of things in a very short time when browsing the web. So any user allowing that in his Browser settings is out of his mind.
Rolf Kalbermatter
