akala Posted November 15, 2007 Report Posted November 15, 2007 Hi everybody!!! I am working in a remote application with LabVIEW 8.0. I have a serius problem if a client hasn't install the LabVIEW 8.0 Run time engine. How can I ensure from HTML or PHP that the LabVIEW 8.0 run time engine was installed? Do you know a way to install sillently the LabVIEW 8.0 run time engine in a client pc via HTML or PHP? Thanks a lot!!!!!!!!!!!!!!!!! Quote
hooovahh Posted November 15, 2007 Report Posted November 15, 2007 Looking at the NI forum I see that older version of the run-time engine can be installed silently using this command. lvrteinstall.exe /q Not sure if this works for the newer ones. If it doesn't I recommend using a scripting language (like AutoIt3) to run the installer, and press the return character until the installer starts. I don't know of a method to check for run-time engines using html or php. Quote
Ton Plomp Posted November 15, 2007 Report Posted November 15, 2007 QUOTE(akala @ Nov 14 2007, 06:19 PM) Quote Do you know a way to install sillently the LabVIEW 8.0 run time engine in a client pc via HTML or PHP?Thanks a lot!!!!!!!!!!!!!!!!! I doubt it, it would be a very risky situation if this could be done QUOTE(hooovahh @ Nov 14 2007, 07:26 PM) Looking at the NI forum I see that older version of the run-time engine can be installed silently using this command. lvrteinstall.exe /q Not sure if this works for the newer ones. If it doesn't I recommend using a scripting language (like AutoIt3) to run the installer, and press the return character until the installer starts. I don't know of a method to check for run-time engines using html or php. The quiet install still works (in 8.5) Ton Quote
Rolf Kalbermatter Posted November 20, 2007 Report Posted November 20, 2007 QUOTE(akala @ Nov 14 2007, 12:19 PM) Quote Do you know a way to install sillently the LabVIEW 8.0 run time engine in a client pc via HTML or PHP? No way with any recent OS! The ability to start any executable remotely through a HTTP connection is exactly what all Adware, Malware and other suspect programmers would like to have. A system that allows that will be invested with these kind of things in a very short time when browsing the web. So any user allowing that in his Browser settings is out of his mind. Rolf Kalbermatter Quote
