Michael Aivaliotis Posted November 16, 2007 Report Share Posted November 16, 2007 Not sure what causes this but I've experienced this several times lately. I run a toplevel VI several times and somewhere I get an error on the error cluster. So I decide to start debugging by opening up the subVI's. When I open one of the subVI's I notice that it has a broken run arrow and now I also notice that my toplevel VI has a broken run arrow. How is it possible for LabVIEW to run broken code? The only thing I can think of is that the broken code has not propogated to the current running application instance until I open it up. Not sure why however since I only have one instance. I have the project environment open too. Quote Link to comment
jdunham Posted November 17, 2007 Report Share Posted November 17, 2007 Do you have a conditional disable structure on the diagram or in a subvi? If you have changed the conditional symbol definition in your project, then the same VI could definitely be working inside the project but broken outside of it. Quote Link to comment
Michael Aivaliotis Posted November 17, 2007 Author Report Share Posted November 17, 2007 QUOTE(jdunham @ Nov 15 2007, 05:42 PM) Do you have a conditional disable structure on the diagram or in a subvi? If you have changed the conditional symbol definition in your project, then the same VI could definitely be working inside the project but broken outside of it. No, it's not that. Quote Link to comment
silmaril Posted November 17, 2007 Report Share Posted November 17, 2007 Did you try Ctrl-Shift-Run on your top level VI? Was the run arrow still unbroken after this? Quote Link to comment
Michael Aivaliotis Posted November 22, 2007 Author Report Share Posted November 22, 2007 Well, it happened again. Check this out. There's a broken wire on the diagram but the arrow's intact. Running the VI crashes LabVIEW. :thumbdown: Quote Link to comment
Val Brown Posted November 23, 2007 Report Share Posted November 23, 2007 Are you working in XP or Vista? Quote Link to comment
Michael Aivaliotis Posted August 21, 2008 Author Report Share Posted August 21, 2008 Here's a video that shows how you can have a broken VI on the diagram of a non-broken VI. No I'm not using a disable structure. If I click on the run arrow of the caller it breaks and shows the error list. The arrow then stays broken. Quote Link to comment
Aristos Queue Posted August 21, 2008 Report Share Posted August 21, 2008 You have filed a CAR, right? Quote Link to comment
LAVA 1.0 Content Posted August 21, 2008 Report Share Posted August 21, 2008 QUOTE (Aristos Queue @ Aug 20 2008, 02:42 AM) You have filed a CAR, right? Have you ever tried to file a CAr without being able to reproduce the issue on demand? I have seen a couple of those myself, also working LV 8.5. I'm not using globals so if its the same bug I have seen it is not due them. THe other observation that I can add is that a really fuzzy general type observation. I would swear (if pressed) that code changes are not propagating to all of the VI's that are not open. I say this because I work with a tree.VI open and after amking changes (but before running) I save everything (from tree.vi save all) then close the tree.vi. Backup then re-open and test the code. WHen closing the tree.vi, I see VI's that want to be saved. As a result I ahve resorted to an old habit of opening and closing the tree a couple of times to make sure all of the changes get propogated. Just reporting what I have ben seing. Ben Quote Link to comment
hfettig Posted August 21, 2008 Report Share Posted August 21, 2008 Hey Mike, I think I found your Broken Arrow. Somehow it found its way into my VI. I seem to be experiencing the opposite of your problem. I have a broken arrow and 0 errors and warnings listed in the error list. Cheers, Heiko Quote Link to comment
Michael Aivaliotis Posted August 23, 2008 Author Report Share Posted August 23, 2008 QUOTE (neB @ Aug 20 2008, 05:36 AM) Have you ever tried to file a CAr without being able to reproduce the issue on demand? I agree. Reporting this to NI is a futile exercise. Not reproducible at all. QUOTE (neB @ Aug 20 2008, 05:36 AM) I would swear (if pressed) that code changes are not propagating to all of the VI's that are not open. I say this because I work with a tree.VI open and after amking changes (but before running) I save everything (from tree.vi save all) then close the tree.vi. Backup then re-open and test the code. WHen closing the tree.vi, I see VI's that want to be saved. As a result I ahve resorted to an old habit of opening and closing the tree a couple of times to make sure all of the changes get propogated. Ben, there's a thread for this issue here. Quote Link to comment
