QUOTE(venkatesh @ Dec 6 2007, 06:28 AM)
hi
i need to access the computer which is in remote.how do i need to communicate(ethernet).plz help in doing so
Rgds
J.Venkatesh
You are going to have to be more specific. There are many, many different ways to access a remote system. What are you trying to do on the remote system, what do you have working so far, etc. The more you give us to work with the more likely it is that you will get a reply.
... computer which is in remote ....
If you are talking about "Remote PC Access", I prefer Real VNC software (you need it installed on both PC, Remote and Local).
If you are talking about access of a Remote PC from LabVIEW on local PC, that is a different story.
What do you want?
--- Ashish
I am not sure what you are trying to do so I'll take a wild guess.
Start with
Search examples >>> Browse >>> Programmatically Controlling VIs >>> Dynamically Loading and Calling VIs >>> Server - VIServer - Example.vi
Look at the other examples in that section also.
Ben
QUOTE(Norm Kirchner @ Dec 7 2007, 11:36 AM)
Two of these should do the trick
The modern version of our childhood telephones :D
But it's not clear if that is a network outlet or a power outlet. I sure hope for the first.
Rolf Kalbermatter
